Old 04-09-2013, 05:53 PM   #226
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,863
Originally Posted by dwoodward View Post
The statement is, technically correct. Mechanical Engineers assure me that applying rear brake applies torque to the swingarm that compresses the shock and lowers the rear of the bike.
That said, I'm surprised if it's actually MSF accepted practice to go there with BRC students; anyone (Slartidbartfast?) care to comment?
It's not stated in the curriculum so no, I wouldn't go there with noobs. If more advanced students wanted to discuss it because they had heard it elsewhere, then I would still probably only discuss it with them and not with the entire class.
Again, I'd like to hear commentary from other current RCs...
And the problem is? (The reason is they need to learn where it is, and they don't have to let go of anything to do it.)
They're teaching friggin' beginners, dude. It might not be important to you, me, or anyone else reading this, but it sure makes the n00bs feel better. Don't believe me, come on over, I'll put a new rider on a bike that's too tall and I'll let you help them pick it up the first dozen times.
IIRC BRC curriculum does NOT require you should be able to flat-foot the training bike, but it sure is a good idea when teaching someone who hasn't ridden before and you'd be pretty stupid to deliberately put someone onto a bike where they couldn't reach the ground. Your typical overweight middle-aged female has more than enough trouble with a 250 rebel. I can't imagine putting them on a tall bike. That said, I have had some good students who were sufficiently "altitude challenged" to have to tip-toe a nighthawk but wanted to ride a "proper bike" instead of a cruiser style. They are usually NOT the ones that have trouble anyway.
You appear to suffer under the common delusion that the BRC was ever meant to be the end-all be-all of motorcycle safety. It's not- it's supposed to be just enough knowledge and skill to get out and learn more on their own. This is why I when it's compared to other places.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 04-09-2013, 06:35 PM   #227
foxtrapper
Oddometer: 778
Mmm. Loved my engineering dynamics text book back when I was working on my mechanical engineering degree. Showed absolutely positively why and how a wheelie on a motorcycle is a physical impossibility. I found it laughable, the rest of the class took it as gospel.
Teaching students to delay using 70-80% of their braking, in the name of safety, is appalling, imo.
And for the record the claim wasn't applying the rear brake lowers the tail. The claim is that applying the rear brake first reduces the nose diving you get when applying the front brake. A claim I do not agree with. Simplly put, X amount of braking force on the front wheel imparts Y amount of force along the coil springs of the fork tubes, which results in Z amount of compression of those springs. Regardless of the rear braking activity. Physics 101.
foxtrapper is offline   Reply With Quote
Old 04-09-2013, 09:23 PM   #228
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,256
Had to lay er down!
Jim
Old 04-10-2013, 06:09 AM   #229
steelerider
Southafricanamerican
steelerider's Avatar
Oddometer: 912
The only time I would use this phrase, would be while I was talking to someone about their mom.
steelerider is offline   Reply With Quote
Old 04-10-2013, 06:12 AM   #230
KX50002
NooB, my ass
KX50002's Avatar
Oddometer: 1,827
SOTGMOTT Some Of The Gear Most Of The Time
KX50002 is online now   Reply With Quote
Old 04-13-2013, 09:25 AM   #231
Falconx84
Lurker
Oddometer: 371
Applying the rear slightly before the front helps settle the bike and prevent some of the dive towards the front. It works, try it.... at least on all bikes I've ridden. One potential variable is they were all chain drive so I can't speak on shaft or belt drive. Another is that I've never had linked brakes or abs - YMMV.
The detail I think you're missing is that the front does not work completely separate from the rear. One part of the system affects how the rest of the system responds.
Other than that, its interesting how your class says you can't wheelie a motorcycle and that's bs... but physics 101 says braking on front and rear are completely separate with no interaction and this is gospel.
V-Strom DL1000k7
Falconx84 is offline   Reply With Quote
Old 04-13-2013, 11:49 PM   #232
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,682
My monolever BMW works this way.
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 04-14-2013, 08:57 AM   #233
garandman
garandman's Avatar
Oddometer: 6,145
2012 WR250R, 2009 TW200, 2008 Tiger 1050 ABS, 2008 CRF100F
“The problem in defense is how far you can go without destroying from within what you are trying to defend from without.” ― Dwight D. Eisenhower
garandman is offline   Reply With Quote
Old 04-14-2013, 09:35 AM   #234
DOGSROOT
OUTSIDE
DOGSROOT's Avatar
Oddometer: 784
vs.
Does the Wolf use his front brakes?
In what sense can economics still claim to be a science if its predictive capacity is so dismally low?
Timothy Garton Ash
This drug won't cure you...but it will put your symptoms to shame
DOGSROOT is online now   Reply With Quote
Old 04-14-2013, 10:27 AM   #235
garandman
garandman's Avatar
Oddometer: 6,145
Well, the Wolf seems to have the same black half helmet and Marlon Brando jacket as the "Sheep."
Old 04-14-2013, 02:58 PM   #236
baloneyskin daddy
bikaholic
Oddometer: 2,102
They don't stray to far from the pack.
baloneyskin daddy is offline   Reply With Quote
Old 04-14-2013, 09:27 PM   #237
DOGSROOT
OUTSIDE
DOGSROOT's Avatar
Oddometer: 784
Ahem...
A Wolf in Sheep's clothing, perhaps?
Timothy Garton Ash
Old 04-15-2013, 07:38 AM   #238
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,633
Yep.
And Mr Wolf Biker has the Pirate Scowl down pat, too.
--Bill
'73 R60/5 Toaster
Old 04-15-2013, 12:39 PM   #239
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,419
Originally Posted by Bill Harris View Post
Yep.
--Bill
Oh look, a Texas Aggie erotic dream!
Albie is offline   Reply With Quote
Old 04-30-2013, 06:09 AM   #240
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,529
Damn, I didn't have my camera or cell phone but a guy and I rode a bit up Highway 143 East of Robbinsville,NC to drag a Harley back on the road with his Jeep. The bike was only down the side of the hill a little bit so it was a no big deal with little damage except a bent up crash bar,etc. The little pirate guy was shaken up but able to ride his Hog away.
Anyway, he said he must have hit a rock and had to lay er down.
No sign of any rocks, just a normal curve on a clean asphalt road.
Vince @ SWFL or WNC
2001 Kawasaki W650
2012 Dong Fang DF250RTB
2013 Ice Bear PBZ110-1P sidecar
2015 Ural cT
Bar None is offline   Reply With Quote
Times are GMT -7.   It's 10:38 AM.
