Old 04-02-2013, 07:58 AM   #1
rebelpacket OP
four-stroke earth-saw
rebelpacket's Avatar
Oddometer: 730
/5 Reusing Head Gasket
Hi Folks,
I just got done re-assembling the left hand cylinder and head on my '71 R75/5. When I put the piston circlip in, I heard an audible "click". I used a socket about the same size as the wrist pin to seat it fully home.
However, I did not "proof" (rotate it a small amount to ensure it is in the groove), as I've read in several responses here.
Rather than let it consume my thoughts for the next xx,xxxx miles, I'd like to take it back down, and proof the circlip to make sure its in the groove.
Can I re-use the new head gasket I just put in? Its only been torqued down. Engine has not been run yet. I'd rather not dish out the money and have to wait again if I can avoid it. Its going to be messy enough cleaning the hylomar off the new base gasket.
Buy it, use it, break it, fix it.
rebelpacket is offline   Reply With Quote
Old 04-02-2013, 08:23 AM   #2
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,040
Yes, I have done this with no problems.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 04-02-2013, 08:48 AM   #3
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 896
Yep. Don't even stress too much about it.
Kt-88 is offline   Reply With Quote
Old 04-02-2013, 09:10 AM   #4
Plaka
Brevis illi vita est
Oddometer: 4,609
Originally Posted by rebelpacket View Post
Hi Folks,
Soak the base gasket in some acetone or MEK..
If the re-used head gasket squeals, easy enough to put in a new one later.
Old 04-02-2013, 09:35 AM   #5
rebelpacket OP
Oddometer: 730
Thanks gentlemen. I figured it'd be ok, but better safe than sorry.
Old 04-02-2013, 11:19 AM   #6
rebelpacket OP
Oddometer: 730
Of course, got it off and the circlip is seated just fine, proofed it and it spun.
Little brake cleaner to get the hylomar off the sealing surfaces, and its all going back on.
A few flecks of the blue (glue I guess?) stuff from the headgasket came off, but otherwise it looks solid. Thanks again for the advice chaps!
Old 04-02-2013, 02:58 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,930
Better safe than sorry.
The damage done by one of these not holding is incredible.
---Albert Einstein
disston is online now   Reply With Quote
Old 04-02-2013, 03:17 PM   #8
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,153
The head and cylinder didn't need to be separated to do this (which is a similar operation to replacing the pushrod tube seals). You could have just eased the cylinder+head assy up enough to expose the wrist pin clips and spooged the Hylomar off with brake cleaner.
The blue flecks were an elastomer sealant from around the upper head bolts, added to the new head gaskets because those points are seep- and weep-prone. Hopefully you put a faint wipe of sealant back to replace what was disrupted...
--Bill
'73 R60/5 Toaster
Times are GMT -7.   It's 04:07 AM.
