Old 04-02-2013, 10:17 AM   #1
feetchermancj OP
Oddometer: 19
84 Yamaha Xt 600 oil Leak
I bought a 1984 Yamaha XT 600 a couple days ago as my first bike. I love it! Out riding I noticed it was leaking oil on the right side of the crank case. I found a gouge/tear in the gasket. If I'm not mistaken this is called a crank case gasket? Its the gasket furthest on the right of the crank case. Would replacing this gasket just mean, draining the oil, removing the kickstart leaver, and pulling the right hand crank case cover? Or am I going to have parts flying all over the place when I pull the cover? Thanks.
feetchermancj is offline   Reply With Quote
Old 04-02-2013, 11:25 AM   #2
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,388
BTDT.
You have to mess with the kickstarter and maybe the decompression cable. Also the oil filter cover has to come off first. DON'T over torque the bolts, if you strip any of the threads up on the case it's a PITA to heilicoil them.
The old XT knows how to leak oil like an old HD. DAMHIK
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 04-02-2013, 11:32 AM   #3
feetchermancj OP
Oddometer: 19
Am I correct in calling it the right hand crank cover gasket? Need to know which part to order. Thanks!
Old 04-02-2013, 09:22 PM   #4
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,249
Thumb Clutch Cover Gasket for a XT 600 ???
How about you call it a: "Right side clutch cover gasket." Thats what it is call on the web site. ED XT 600 Fan!!!
BIG ED XT FAN is offline   Reply With Quote
Old 04-03-2013, 09:18 AM   #5
feetchermancj OP
Oddometer: 19
Thank you! This is my first bike so I'm still learning.
Old 04-03-2013, 10:28 AM   #6
feetchermancj OP
Oddometer: 19
Does anybody know the torque values for the clutch cover bolt? Thanks.
Old 04-03-2013, 08:26 PM   #7
BIG ED XT FAN
Oddometer: 1,249
Xt 600?
You can run the bolts in and stop went no more shaft is showing. And turn it just a little more. And it will stopped. Thats it. Use a short racket to turn the bolt in. It takes practice to get it right. BIG ED XT&TT 600 Fan!!:fre aky
Times are GMT -7.   It's 11:29 AM.
