Old 04-02-2013, 10:58 AM   #1
cbig OP
Rift- Raft, SCooter Trash
cbig's Avatar
Oddometer: 970
Plastic welding/glue
Need help welding or gluing the plastic headlight holder on my xr400. Cracked it good, seems to be the same stuff as the fenders. Any recommendations?
Weld, glue, what to use and where to get?
Thanks,
Cbig
Cbig
cbig is offline   Reply With Quote
Old 04-02-2013, 11:01 AM   #2
mcma111
mcma111's Avatar
Oddometer: 12,392
I might/should have a XR400 head light shroud. I'll have to look.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 04-02-2013, 11:02 AM   #3
tcourdin
Resident Spooner
tcourdin's Avatar
Oddometer: 10,681
Thanks,
Cbig
Wally world/auto stores sell plastic epoxy. They come in a 2 part tube and you mix them together. I've used a few different brands and they all work well.
My SPOT
tcourdin is offline   Reply With Quote
Old 04-02-2013, 11:14 AM   #4
cbig OP
cbig's Avatar
Oddometer: 970
Steve
Thanks but that won't work. The dual sport kit is Electrolux which is gone. I cracked their light kit and need to glue or weld it. No replacement for this.
Thanks,
Chuck
Cbig
Old 04-02-2013, 11:45 AM   #5
TinkerinWstuff
Take it apart
TinkerinWstuff's Avatar
Oddometer: 1,292
I've plastic welded many motorcycle plastics. Best and most reliable fix out there. Takes some practice to get the technique and requires sanding, filler, and paint to look like new.
1999 Suzuki DR650
1998 Honda VFR800 Interceptor
http://share.findmespot.com/shared/f...KJutW9osVpn3hd
TinkerinWstuff is offline   Reply With Quote
Old 04-02-2013, 12:05 PM   #6
cbig OP
cbig's Avatar
Oddometer: 970
How is this done?
Special tools or something like a tip on a soldering iron? How do I know I have the right "rod?"
thanks
Cbig
Old 04-02-2013, 12:45 PM   #7
DustyRags
Idiot
DustyRags's Avatar
Oddometer: 720
If there's any sort of real surface area, superglue works great on plastic, but it doesn't sound like that's the case.
Otherwise, epoxy. Man, that stuff is amazing. Bit of a smelly mess, and make sure you get it in the right temperature (too cold and it won't cure right), but if you follow the directions, you'll end up with a bomb-proof material that looks like melted plexiglass and sticks to anything. Rough up the plastic with some sandpaper first, and it'll be like new.
DustyRags is online now   Reply With Quote
Old 04-03-2013, 07:02 AM   #8
LukasM
Oddometer: 5,425
Any thermoplastic is best fixed by plastic welding it with the same kind of material and a soldering iron at the right temperature and a suitable tip.
Figure out what material that is (look for markings on the part, then search the internet for explanations of the code), and then either find another piece of plastic like it or order pieces of rod online.
Old 04-03-2013, 07:13 AM   #9
drrod1
drrod1's Avatar
Oddometer: 138
If you are in a bind and are not afraid of it looking a bit messy, use crazy glue and baking soda.
If possible, make the sides of the crack as much of a V as possible, fill with crazy glue and sprinkle baking soda on top of the wet crazy glue.
You will get an amazingly strong bond.
Rod
drrod1 is offline   Reply With Quote
Old 04-03-2013, 07:22 AM   #10
ramjet
ramjet's Avatar
Oddometer: 2,271
http://www.urethanesupply.com/
Great source for plastic welding info and supply. Their Plasti-Fix is kind of a universal. Scroll down to documents section and you can download a handbook. He also publishes a book that is very useful also.
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is offline   Reply With Quote
Old 04-03-2013, 07:37 AM   #11
SkiBumBrian
DualSport Crazy !!
SkiBumBrian's Avatar
Oddometer: 1,051
Lukas nailed it on the head. I have welded a fairing with material from the stock hand guards I removed. I good welding tip and like material is the best way. I have also used a 2 part epoxy Marine Tek but welding with same material is the best.
Good luck, I think you will be surprised how well that works! Afterwards just sand and buff it, viola!
"Where ever you are, there you go..."
SkiBumBrian is offline   Reply With Quote
Old 04-03-2013, 09:25 AM   #12
cbig OP
cbig's Avatar
Oddometer: 970
Thanks for the tips
Harbor freight has a kit I will check out. Wish I could just use a soldering iron or torch but I see how it needs to be mixed in. One piece is black and thin, the other actual fairing type piece holding headlight is as thick as a fender.
Cbig
Times are GMT -7.   It's 02:59 PM.
