Old 04-02-2013, 12:40 PM   #1
Hootowl OP
Oddometer: 1,262
Need a New Battery? Check This
http://www.advrider.com/forums/showthread.php?t=875554
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl screwed with this post 04-02-2013 at 12:59 PM
Hootowl is online now   Reply With Quote
Old 04-02-2013, 01:18 PM   #2
stevodadevo
What happened?
stevodadevo's Avatar
Oddometer: 177
What size fits the 990?
EDIT: Ehh all the prices already went up with long lead times.
stevodadevo is offline   Reply With Quote
Old 04-02-2013, 01:53 PM   #3
sledstorm1
CT RAMBLER'S MC CLUB
sledstorm1's Avatar
Oddometer: 870
ATZ14SBS 26 bucks
To those who understand, no explaination is necessary
Too those who don't, none is possible...
sledstorm1 is offline   Reply With Quote
Old 04-02-2013, 01:56 PM   #4
Hootowl OP
Oddometer: 1,262
Originally Posted by sledstorm1 View Post
ATZ14SBS 26 bucks
For the 990/950 I think its ATX9BS Length 150MM (5 7/8) Height 110MM Width 85MM (3 1/4)
Except the postive & negative terminals are reversed
'07 990A
'12 Super Tenere
Old 04-02-2013, 02:04 PM   #5
ABuck99
0.0
ABuck99's Avatar
Oddometer: 598
Yuasa YTZ14S MF- Stock, but there are many other options & brands available. ATX9 will not deliver enough power- not even enough for a 690. Stick with AGM- GEL or LiFePo not the acid filled ones you'll find discussed in that linked thread. Acid filled don't have the equivalent power output or life expectancy of the AGM- GEL or LiFePo. And the acid filled are not suited to handle heat very well, internal plates break from vibration, bumps & jolts when off roading your 990/950.... And lead acid batteries leak when laying on their side....
See page 32
http://www.ktm950.info/library/asset...nual%20unc.pdf
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 screwed with this post 04-02-2013 at 02:19 PM
ABuck99 is offline   Reply With Quote
Old 04-02-2013, 02:11 PM   #6
sledstorm1
sledstorm1's Avatar
Oddometer: 870
I used this
If you're uncertain at all about which to order, follow this link:
http://webcaps.ecomm.gm.com/internet...Automotive.jsp
Old 04-02-2013, 02:24 PM   #7
RadoR6
Oddometer: 59
Originally Posted by ABuck99 View Post
Yuasa YTZ14S MF- Stock, but there are many other options & brands available. Stick with AGM- GEL or LiFePo not the acid filled ones you'll find discussed in that linked thread. Acid filled don't have the equivalent power output or life expectancy of the AGM- GEL or LiFePo. And the acid filled are not suited to handle heat very well, internal plates break from vibration, bumps & jolts when off roading your 990/950.
Are you sure? As far as I know AGM(absorbent glass matt) battery is also filled with acid as normal acid lead battery(acid remains liquid),the difference is that acid is absorbed in some sort absorbing material to avoid spilling in case the battery becomes damaged.AGM batt. can be bought from the manufacturer filled/sealed or dry with pack of acid and you do the filling at home-have bought one dry AGM Yuasa for my R6 last year and spent half an hour playing with it.
RadoR6 is offline   Reply With Quote
Old 04-03-2013, 04:32 AM   #8
ABuck99
0.0
ABuck99's Avatar
Oddometer: 598
Some AGM come pre-filled from the supplier, but right, the AGM Yuasa is not. Clarifying my point that the cheaper conventional batteries will not last long in offroad use. AGM or Gel batteries withstand vibration-shock-& heat significantly better than conventional lead acid batteries, dont spill when tipped, hold a static charge longer between uses, and generally have have higher CCA.
Old 04-03-2013, 08:24 AM   #9
stevodadevo
What happened?
Oddometer: 177
ATZ14SBS 26 bucks
You're right! Just picked one up for $26 plus tax.
Times are GMT -7.   It's 06:45 AM.
