Old 04-03-2013, 01:55 AM   #1
munsey8 OP
munsey8's Avatar
Oddometer: 36
990 Adv - Pass/Flash button
The button/switch which flashes the main beam doesn't seem to be working.
Is this a known issue/easy fix?
munsey8 is offline   Reply With Quote
Old 04-03-2013, 06:35 AM   #2
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,280
Check the bulb? It also doesn't work when the high beam is on. If those aren't the problems, I'd pop open the cover to see if it is getting power.
Orangecicle is offline   Reply With Quote
Old 04-03-2013, 06:37 AM   #3
munsey8 OP
munsey8's Avatar
Oddometer: 36
Cheers for the reply. The flash uses the same bulb as high beam does it not?
If it does my high beam is ok. So must be something to do with the switch. I will try take a look at the switch tonight.
Old 04-03-2013, 04:30 PM   #4
scottrnelson
Team Orange
scottrnelson's Avatar
Oddometer: 1,513
The only difference is that with flash to pass, the low beam stays on in addition to the high beam. It's a better way to get more light on tight roads at night.
scottrnelson is online now   Reply With Quote
Old 04-03-2013, 05:42 PM   #5
Orangecicle
On a "Quest"
Oddometer: 3,280
Or you could run new wires to it and make it a contact for your garage door opener!
Old 04-04-2013, 04:37 AM   #6
R&R4adv
R&R4adv's Avatar
Oddometer: 340
Or rewire it to operate your mode on your speedo instead of getting a trip master switch it works great
R&R4adv aka Reon
04 950 Adventure
past bikes
04 950 Adventure 03 640 Adventure 99 XR400
R&R4adv is offline   Reply With Quote
Old 04-04-2013, 08:53 AM   #7
munsey8 OP
munsey8's Avatar
Oddometer: 36
If I had a garage I'd definately do this haha!
This isn't a bad idea actually! Any info/guides on it that you know of? Would be very handy.
Old 04-04-2013, 09:20 AM   #8
scottrnelson
Team Orange
Oddometer: 1,513
Question
I don't understand what you're asking. When low beam is on and you use the flash to pass button you get more light.
You want a whole analysis of that???
Old 04-04-2013, 09:41 AM   #9
munsey8 OP
munsey8's Avatar
Oddometer: 36
No my flash button doesn't flash at all. Main beam works. Flash button no worky lol
Old 04-04-2013, 10:09 AM   #10
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,865
Have you updated the firmware?
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Times are GMT -7.   It's 03:05 PM.
