Old 04-05-2013, 08:15 AM   #1
ShaiDanny OP
ShaiDanny's Avatar
Oddometer: 41
Disc rotor bolts
Hey fellaz,
I have a question regarding the bolts that hold the disc rotors. Stock bolts are called "Special Screw" and are made of 10.9 steel. Their head is solid, unlike the ones that have a T35 torx inside the 8mm hex. Is there a problem using the M6x13 ones that have the torx, also made of 10.9 steel?
Or should I stick with the solid head ones?
Thx
ShaiDanny is offline   Reply With Quote
Old 04-05-2013, 08:52 AM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,002
I don't know.
I do now your 950 is measuring speed counting the disc screws that pass close to you speedometer sensor. You could try and see if you get normal speed readings with the torx bolts and add your outcome to the OC knowledge.
Cheers.
gefr is online now   Reply With Quote
Old 04-05-2013, 12:29 PM   #3
ShaiDanny OP
ShaiDanny's Avatar
Oddometer: 41
...the thing is, I already replaced all bolts...
While riding with the gang today, I noticed that all of their bikes are using the solid head bolts, so a red light came on in my brain.
The question is about the strength of the bolts - are the torx bolts in newish KTM's the same as the solid ones used for the brake rotors? Both have a rating of 10.9.
And the speedo reads just fine BTW.
Thx
Old 04-05-2013, 03:16 PM   #4
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
10.9 is 10.9. I see no problem there. Just remember the locktite that goes with them.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is online now   Reply With Quote
Old 04-05-2013, 03:53 PM   #5
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,952
Also might want to look at the physical bolts.
Since in this application your main interest is in resistance to shear do the stock bolts have a shoulder on them while the other you used are threaded the full length of the shaft.
If that is a case the shouldered bolt would be stronger in the same application.
Worth taking a look at.
This
vs
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 04-06-2013, 07:52 AM   #6
ShaiDanny OP
ShaiDanny's Avatar
Oddometer: 41
The stock bolts are threaded the full length as well.
Old 04-06-2013, 08:35 AM   #7
nomad guy
A legal alien
nomad guy's Avatar
Oddometer: 847
You shouldn't have any problem as long as the bolts meet the same spec, 10.9, and everything is functional. Make sure that the new Torx type bolt has the same size head or larger to prevent heirloom cracks in the disks.
Don't skip the Loctite.
Cheers
Guy
04 KTM ADV 950S GO!!!!!
09 KTM 690 ENDURO R
nomad guy is online now   Reply With Quote
Old 04-06-2013, 09:47 AM   #8
DSM8
DSM8's Avatar
Oddometer: 3,952
Then so long as they are the same material and the head is the same diameter it should be a non issue.
Post up some pics of the two bolts be interesting to see them.
Old 04-06-2013, 01:42 PM   #9
Peanuts
Peanuts's Avatar
Oddometer: 1,664
Whats the part number of the screws you are using?
Stock 950 front disc screws have a flat top with 10.9 stamped into them
59009062013SPECIAL SCREW M6X13 WS=8 10.9
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 03:18 PM.
