Old 04-10-2013, 04:43 AM   #1
990s OP
Oddometer: 47
Clutch push rod
Hi does anyone know the correct length of the clutch push rod (60032054400) ?
My clutch wont disengage proberly, i cant find anything wrong anywere(slave,booster,
disks etc) but the rod seems to have taken some beating in the clutch slave end that might have shortened it. Thanks!
990s is offline   Reply With Quote
Old 04-10-2013, 06:15 AM   #2
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,997
There have been some different length editions.
I suggest you try installing a spacer and see what happens.
Cheers.
Old 04-15-2013, 10:37 AM   #3
990s OP
Oddometer: 47
Cheers.
but how?
Old 04-15-2013, 12:19 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,997
In the clutch slave culinder
You will have to unbolt the slave cylinder on the left side of the bike and install a washer in the end of the pushrod. However the liquid clutch assembly is there to compensate small changes by usint supplementary hydraulic liquid from the liquid tank. Are you sure you are not experiencing clutch slave cylinder failure?
http://advrider.com/forums/showthrea...171986&page=30
Old 04-15-2013, 12:42 PM   #5
Sevv
Oddometer: 101
A small air bubble in the line will cause this...
Sevv is offline   Reply With Quote
Old 04-15-2013, 02:41 PM   #6
990s OP
Oddometer: 47
I have changed the slave, and i think i have all the air out of the system. It is not to expensive to change the rod (23 euro). It is kind of battled and worn on the slave (thin) side. Since i think it might affect its performance i will probebly just change it... Cheers!
Times are GMT -7.   It's 09:48 PM.
