Old 04-06-2013, 08:27 AM   #1
tilting40s OP
Oddometer: 57
Rally Tail Light KTM 990
Ok tail light in looks cool, but there are small gaps at the front because of the curvature of the fender. I need some sort of softer rubber spacer that can compress to fill these gaps but not so much that it bubbles out in higher compression areas (needs to be water tight). I was thinking of something like a skateboard truck riser, but softer. Ideas........
tilting40s is offline   Reply With Quote
Old 04-06-2013, 08:56 AM   #2
KTMSAM
KTMSAM's Avatar
Oddometer: 123
There's probably a better option out there too, but the first one I thought of was the double stick foam that comes in a roll, possibly like the 3M #03609? It would certainly do the trick, but depends how much gap you need to fill.
Good luck,
KTMSAM
"KTM? Who makes that?"
KTMSAM is offline   Reply With Quote
Old 04-06-2013, 02:44 PM   #3
Peanuts
Peanuts's Avatar
Oddometer: 1,571
Black silicon sealant? Mask off and run a wet finger over the bead to smooth out.
Peanuts is offline   Reply With Quote
Times are GMT -7.   It's 03:19 AM.
