Old 04-18-2013, 04:56 PM   #91
brittrunyon OP
R 100 GS F 650 GS
brittrunyon's Avatar
Oddometer: 523
Damn. Had my cam & crank switched in my head, thanks for straightening me out.
1992 R 100 GS (ZED)
2007 F 650 GS
My Motorcycle Videos & More @ http://vimeo.com/user2721333
Big Bend Ride Report @ http://brittrunyon.com/
brittrunyon screwed with this post 04-18-2013 at 05:41 PM
brittrunyon is offline   Reply With Quote
Old 04-18-2013, 05:03 PM   #92
Plaka
Brevis illi vita est
Oddometer: 4,609
Originally Posted by brittrunyon View Post
The yellow paint & dark "burn" mark can be seem here, but one tooth left.
Also, there is an obvious yellow mark on the crank right of the dimple. This confused me.
When I go to line the marks up
........I'll rotate 180 and get the two marks closer together
........which sprocket do I turn? The cam clockwise or the crank counter clockwise?
I've heard sealer on the gasket & I've heard no sealer?
I have Yamabond 4
The key on the cam looks good but can't see the crank key.
Crank always at TDC, and you want that accurate. Match up the cam to that. It's a wasted spark system so it doesn't matter which side leads the show.
Go light on the sealer, why I reccomended easy to remove stuff. I have no experience with the Yamabond. I'd go for a little extra besides just the paper, but not set yourself up for a hassle the next time you go in, either getting the cover off or cleaning the old gasket sealant.
Plaka screwed with this post 04-18-2013 at 05:30 PM
Old 04-18-2013, 06:29 PM   #93
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,985
Oh. I see. ;)
--Bill
'73 R60/5 Toaster
Old 04-18-2013, 06:49 PM   #94
supershaft
because I can
Oddometer: 9,116
This is the second airhead here within a year or so that has had the cam one tooth off. You would think someone would notice the bike not starting well and running like crap? If I remember right, they won't even run with the cam off one tooth the other way?
At any rate, the chain and sprocket are not worn enough for that to be the cause of the trouble. That crank sprocket is worn if I am seeing it correctly. I suspect the chain and guides were just replaced. It would be just fine to time the cam correctly and button it back up. I would be tempted to replace the chain and sprocket IF that sprocket is worn. There is no need to go looking for offset keys.
I would install that gasket clean and dry.
Old 04-18-2013, 07:26 PM   #95
brittrunyon OP
R 100 GS F 650 GS
Oddometer: 523
When I purchased it last month I noticed that it had "funny" way of starting, not that it was difficult to start, just different from my "92 GS.
On cold starts, even with the choke on, I had to open the throttle to prevent it from dieing. I thought it might be the carbs, but that's next. Has a stumble at 1200 rpms as well.
On the road it's just powerless.
And then of course "we" couldn't time it.
I, with my eagle eye, see some wear on the crank sprocket. I know it's hard to diagnose looking at photos.
If "they" indeed just replaced the chain & guides, wouldn't it be best to just do her right & refurbish for another 100k?
The bearings feel fine.
Or could I get another 50k the way it is now. Hmmmmmmmmmmmmmmmmm?
Is it worn enough?
1992 R 100 GS (ZED)
2007 F 650 GS
Old 04-18-2013, 08:08 PM   #96
supershaft
because I can
Oddometer: 9,116
100k miles out of an airhead timing chain? Good luck! Your going to need it but then again a lot of airhead owners don't mind their airhead clinking and clacking and running like crap while it shakes and shutters and pukes oil all over itself. It seems as if some airhead owners are kind of proud of just how bad their airheads can look and sound and still just barely run.
A entirely new setup will need replacing in 60 or 80k if you want it to sound and run like a top. New chains on worn sprockets should be good for 30 or 40K?
I would get your chain and sprocket from a dealer. There are junk chains out there!
Old 04-18-2013, 08:39 PM   #97
Plaka
Oddometer: 4,609
Is it worn enough?
What does the pluck-the-chain test reveal?
I already bet myself an ice cream bar on what you're going to do. At 5k a year 50000 miles is ten years. You won't consider this.
Old 04-18-2013, 08:43 PM   #98
Plaka
Oddometer: 4,609
Originally Posted by Bill Harris View Post
Oh. I see. ;)
--Bill
Root of a negative number. Creative. Makes things more complex but nothing a good imagination can't handle. Didn't you mean to post over in the "Bird Strikes" thread in Perfect Line...
Old 04-19-2013, 12:27 AM   #99
Bill Harris
Oddometer: 7,985
Whoosh.
'73 R60/5 Toaster
Old 04-19-2013, 12:31 AM   #100
Bill Harris
Oddometer: 7,985
When I purchased it last month...
Yep, that sprocket is done wore out.
Just last month? A lot has happened...
--Bill
'73 R60/5 Toaster
Old 04-19-2013, 05:54 AM   #101
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,792
If we are taking a survey, I vote for the crank sprocket is worn, needs to be replaced. I would say the chain and the crank sprocket should be replaced at least.
However, if you are so inclined, and I always don't like such moves, but if you want to just put the gears in time and Blue Glue it back together it would probably be an improvement. But don't do that, please.
---Albert Einstein
disston is online now   Reply With Quote
Old 04-19-2013, 05:58 AM   #102
brittrunyon OP
R 100 GS F 650 GS
Oddometer: 523
"Pluck the chain"
How much slop should there be in the chain with the guide & tensioner off?
1. none
2. 1/4 inch
3. 1/2 inch
4. 3/4 inch
5. 18 inches
6. none of the above
What's your favorite ice cream?
1992 R 100 GS (ZED)
2007 F 650 GS
Old 04-19-2013, 06:17 AM   #103
Plaka
Oddometer: 4,609
How do you know the crank sprocket is worn? or the chain for that matter?
This keeps coming up what isn't coming up is the OP saying: "see, here's the wear"
It has 139k on it and the last 12 years of service records are missing. This is difficult to puzzle out from the original post, which is as scattered as an eighth grade algebra problem. But it's an unknown except that a) by this mileage it likely due and B) someone was monkeying around in there. So my vote is the stuff was replaced fairly recently, and incorrectly.
And I'm backing that up with a ChocoTaco (which I may get anyway)
Plaka screwed with this post 04-19-2013 at 06:25 AM
Old 04-19-2013, 06:37 AM   #104
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,792
I base my opinion on the photo. The crank sprocket looks worn. My experience is to replace questionable parts for known good parts. This is an opinion and it is the way I decide such things. That is, the decision is made to make the repair in such a manner that it is a known good repair. Not to make the repair two or three times because I thought I could reuse the crank sprocket.
I think the OP is asking "what measurement?" You got a figure? What if it's on the border? How about the noise? Put it back together and change the timing chain when you can hear it through a full face helmet?
It is today a great day to ride. My car is broken down and I went for coffee. Hopefully the part for my car will be in and I get to drive my car for one more month. This car dies in about 40 days. A bummer. Fix your bike once and go for a ride. I will soon be only riding no driving, it looks like.
---Albert Einstein
Old 04-19-2013, 06:38 AM   #105
Plaka
Oddometer: 4,609
"Pluck the chain"
1. none
2. 1/4 inch
3. 1/2 inch
4. 3/4 inch
5. 18 inches
How much is there? got a pic? You want the lift mid wrap.
ChocoTaco's
Observing quite a few threads now I've noticed a strong preference for swapping out parts, including buying new parts, over analysis. I shouldn't be surprised. But then I keep my head pretty far down. Keeps me (somewhat) sane. Still I'm puzzled. If ones problem solving style is to just throw money at something rather than thinking about it, where do they get the money?
Times are GMT -7.   It's 09:24 AM.
