Old 04-07-2013, 10:19 PM   #1
snohobo OP
Supermoto hippy
snohobo's Avatar
Oddometer: 426
08 KTM 690 - FI light - bike runs rough - induction manifold pressure?
Howdy folks,
None of you might remember but I rode my 690 from Colombia to Argentina last year - and shipped it back in May.
Thread here....
http://www.advrider.com/forums/showthread.php?t=729679
I haven't been riding lately but last week I was getting the bike back together, putting on some new parts, etc...
The only engine related part I put on was a new Remus pipe. Other stuff was new tires, plastics, cogs, sprocket, chain...
I noticed that the bike would turn over, but not start. Battery was charged, fuel pump priming - but it just wouldnt catch.
I had the upgraded fuel injector in my spare parts bag - and thought that might be the problem - so i installed it. Sure enough - the bike would now start, and idle - but would refuse to run. I could get it going in 1st and 2nd - but the bike would backfire badly, and die when the rpms dropped to idle.
Then the FI light came on - 9 blinks which indicate - Input signal from pressure sensor of induction manifold too low/high ktm.
What the hell and where the hell is the pressure sensor of induction manifold?
In Colombia - i had another related issue where the bike wouldnt start - and I got the same FI light. I brought it to the dealer and they cleared the code and put in a new spark plug and that seemed to fix the problem - for about 15,000 miles.
Does anyone know anything about this code? I can only find 2 examples of it ever being mentioned on google - and both didnt have much info.
Ride Reports:
Supermoto Around Death Valley - In Progress
Supermoto Around South America - Terminado
snohobo is offline   Reply With Quote
Old 04-08-2013, 12:54 AM   #2
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 982
MAP sensor sits on top of the throttle body. Check connectors for corrosion.
See this diagramme:
http://www.hondapartspitstop.com/pag...7e18%7c%7e0041
Don't know if that helps.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 04-08-2013, 09:33 AM   #3
snohobo OP
Supermoto hippy
snohobo's Avatar
Oddometer: 426
See this diagramme:
I'll inspect it, and clean it tonight. I'll report back - thanks for the tip.
Ride Reports:
Old 04-09-2013, 05:25 PM   #4
snohobo OP
Supermoto hippy
snohobo's Avatar
Oddometer: 426
Was connected fine, sensor appeared clean and in working order. Cleaned and reconnected it - still getting an error.
Worth getting the tuneECU cable and resetting the code myself?
Ride Reports:
Old 04-10-2013, 10:44 AM   #5
Bill the Bong
Supern00ba
Oddometer: 982
I would check the wiring for continuity to the sensor. Also check for breaks in the insulation that could cause a short to earth. Also make sure that it is 9 short blinks, not 9 long ones, thta would be the TPS not the MAP sensor.
Old 04-10-2013, 11:51 AM   #6
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,893
you tried the 15 min idle reset?
perhaps the remus has not enough back pressure
wrk2surf is offline   Reply With Quote
Old 04-10-2013, 04:20 PM   #7
snohobo OP
Supermoto hippy
snohobo's Avatar
Oddometer: 426
I did try the 15 min idle reset.
I could try putting the old remus back on. It's the same pipe - but the new one is less damaged and has a different mounting bracket.
I'll get cranking on all of this tomorrow - work calls!
Thanks for all your help so far people. Much appreciated.
Ride Reports:
Times are GMT -7.   It's 01:09 AM.
