Old 04-08-2013, 07:09 AM   #1
DaddyBigDaddy OP
AKA -Evel Kneilson
DaddyBigDaddy's Avatar
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 308
How do I run/get hi fender dual disc 640 brake lines?
The stock Brake crossover line is too short for a high fender setup and I wand to keep dual discs.
Is there a longer right caliper cable available from Ktm and if so how to route it?
DaddyBigDaddy
1998 KTM 620 Adventure
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy is offline   Reply With Quote
Old 04-08-2013, 11:30 PM   #2
Maurizio
2 smoker
Maurizio's Avatar
Oddometer: 163
Buy a second left side brake line, cable guides (the metal wire low one, the lower triple clamp plastic and something similar to use on the higher triple clamp), a pair of '04 KTM 80 cc mini mx fork guards and some brake line holder for the right one.
Remove the left brake caliper long banjo bolt and use it on the brake pump (use the brake pump one on the left caliper) and you're done...
Some pics of my old 950, that shares the same front end of your 640:
Hope this helps, ciao!
maurizio
'14 250 EXC E "Sparkling Orange"
'08 FLHCTUSE3 - '76 CB 750 F ss
sold: '03 950 adv s, '05 450 exc, '08 690 e
Maurizio screwed with this post 04-17-2013 at 03:02 AM
Maurizio is offline   Reply With Quote
Old 05-08-2013, 07:38 PM   #3
DaddyBigDaddy OP
AKA -Evel Kneilson
Oddometer: 308
Thank you!
Great pix too!
DaddyBigDaddy
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
Old 05-08-2013, 08:32 PM   #4
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
Geek put together this guide, also for a 950, but is the same for the 640. this is the complete parts list, compiled from others and used to put a high fender on my old 640.
Qty Part Name KTM Part #
1 BRAKE HOSE FRONT ADV '03 60013012100
1 BRAKE HOSE GUIDE FRONT '03 60013025000
1 RUBBER FOR BRAKE HOSE GUIDE'03 60013025050
1 FORK PROTECTOR L/S & R/S 85 SX 4700109400030
2 BRAKE HOSE CLAMP MARZOCCHI'95 54601085000
4 SPACER BUSHING 7X10X7,5 50208020000
4 HH COLLAR SCREW M6x20,WS8 0014060203
2 HH COLLAR SCREW M6x15,WS8 0014060153
2 BRAKE HOSE GUIDE 59008019000
1 FRONT FENDER 7650801000004
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Times are GMT -7.   It's 11:41 PM.
