Old 04-08-2013, 08:09 PM   #1
GeoAggie OP
GeoAggie's Avatar
Oddometer: 271
K1600GT vs FJR1300: Handling
I am back to riding after totaling my 2012 K1600GT in an at-fault accident. I was attempting to pass multiple cars and hit the lead one turning left on to a dirt road. Lessons learned and fortunate to be back in the saddle after 5 months.
I am wondering whether to purchase another K1600GT. The bike was amazing in so many ways but very large and heavy. The updated FJR appeals to me as a smaller, lighter (slightly?) and certainly less expensive option. Anyone have seat time on both to compare the handling characteristics? I know both are exceptional tourers but I'm interested in the fun factor in the twisties. The motor on the 1600 is intoxicating and it handles in a way that defies its mass but I'm curious about a direct comparison in riding the curves. Thanks,
Jeff
GeoAggie screwed with this post 04-09-2013 at 06:21 AM
GeoAggie is offline   Reply With Quote
Old 04-08-2013, 11:04 PM   #2
ddddd
Oddometer: 32
What year model did you say your K1600GT was, and how many years did you have it ??
ddddd is offline   Reply With Quote
Old 04-08-2013, 11:42 PM   #3
stripple
Runnin' Hard
stripple's Avatar
Oddometer: 616
I believe that the K1600GT has only been out for one year...
“Who is the happier man, he who has braved the storm of life and lived or he who has stayed securely on shore and merely existed?” Hunter S. Thompson
stripple is offline   Reply With Quote
Old 04-09-2013, 05:54 AM   #4
roadstar
roadstar's Avatar
Oddometer: 362
I'm thinking he ment K1200GT But he did say large , so maybe a K1200LT
IBA # 47424
2012 Concours (Black)
76 Honda GL1000 (red & naked)
roadstar is offline   Reply With Quote
Old 04-09-2013, 06:05 AM   #5
Blue&Yellow
but orange inside...
Blue&Yellow's Avatar
Oddometer: 754
At any rate the FJR is hardly a canyon carver, very slow to flick. And I mean syrup-slow-motion-slow to flick.
If he wants that he needs to look at something like a Tiger 1050 with aftermarket windscreen.
Blue&Yellow is offline   Reply With Quote
Old 04-09-2013, 06:20 AM   #6
GeoAggie OP
GeoAggie's Avatar
Oddometer: 271
Originally Posted by roadstar View Post
i'm thinking he ment k1200gt but he did say large , so maybe a k1200lt
2012 k1600GT, sorry for the typo in my initial post.
Old 04-09-2013, 06:55 AM   #7
20valves
Yamaholic
20valves's Avatar
Oddometer: 449
Originally Posted by Blue&Yellow View Post
[FJR is] syrup-slow-motion-slow to flick.
Complete nonsense. "Flicking" bikes is a great way to crash anyway.
FJR's have very stable, responsive handling and broad, smooth, torquey power. For anything you can do on pavement, an FJR will do it very well and in comfort. And they are bulletproof.
'14 500 EXC, '06 R1 LE, '13 FJR, '12 XTZ12, '09 T Max
20valves is offline   Reply With Quote
Old 04-09-2013, 08:17 AM   #8
GB
Mod Squad
GB's Avatar
Oddometer: 57,127
I've owned both.. and prefer the '13 FJR, very stable in the curves, in sport mode, hold on tight....good wind protection, cruise control is great to have and it's about 100 lbs lighter and thousands $$ less and will be more reliable in the long term. It has just the basics for electronics without lots of whiz bang gizmos that make you dread owning the bike out of warranty. Glad to hear you're doing well and ready to get back in the saddle. Good luck with your new purchase
Old 04-09-2013, 10:17 AM   #9
Haroon
RIDE for PASSION
Haroon's Avatar
Oddometer: 556
GB- Since you mentioned above, a small query on the new FJR. I am torn between an FJR & GTR as my next bike. However, there is no Yam dealer here, but my mechanic friend at Kawasaki is brilliant & works on all the Kawi bikes, so I guess he can do the service/repairs (if any). If I were to import an FJR, does the FJR also need any of those specialized Diagnostic/Service reminder resetting tools etc.....(like BMW) or can it be serviced/repaired by any mechanic, without those specialized stuff?
Growing old is compulsory - growing up is optional
Exploring the world on 2-wheels...little at a time
RIDE for PASSION
www.rideforpassion.com
Haroon is offline   Reply With Quote
Old 04-09-2013, 10:43 AM   #10
GB
Mod Squad
GB's Avatar
Oddometer: 57,127
Buy the shop manual so you have all the torquing specs and maintenance procdures. There's no need for any specialized dealer computer (like bmw) to reset anything. The fuel tank on the bike is hinged at the rear, so it makes accessing the top of the engine to check the valves at 42,000 km easier. The valve check procedure on the GTR14 requires a lot of labor to reach the valves. There's nothing fancy about the valve adjustment either. Accessing the air filter is very easy too and the final drive has easily accessible filler and drain bolts.
The only gripe some Gen III (2013 and newer) have is that the US bikes are limited to a top speed of 82 mph when using the electronic cruise control, i.e. you cannot set the cruise at a speed higher than that.. For me it's not an issue. It's not prudent to use the cruise when traveling at high speeds anyway. European FJR's have a much higher cruise control set limit.
The bike has been around for 10 years, Yamaha has continually tweaked it. Gen III has flawless throttle by wire (unlike the super touchy one used on the K1600), some engine components have been changed for a more efficient operation. Traction control is a great plus for a bike that makes this much power, I'm not crazy about the way the linked brakes operate, I prefer the BMW way: the lever operates front and back.. the pedal only operates the rear.. The FJR, the brakes are linked and for full braking power, you need to operate both.. but the brakes are super strong.
I really like the digital speedometer, very easy to read and the extensive bike computer in the right LCD display allows you to customize the appearance of menu items on the 3 screens. Off the top of my head, the bike computer shows air temp, coolant temp, trip 1, trip 2, odo, liters / 100 km, or KM/liter, current fuel useage, average fuel useage, tank range, there's a timer which I don't care for and probably something else. Also, the heated grips have 3 settings which you can customize their power output.
Old 04-09-2013, 11:05 AM   #11
waveydavey
happy times!!
waveydavey's Avatar
Oddometer: 9,422
I bet more crashes occur because of running wide into the dirt than "flicking" (which can save the inattentive riders ass sometimes).
"...once the honey was gone he wandered off, farting and too soon satisfied."
FUCK CANCER!!!!
waveydavey is offline   Reply With Quote
Old 04-09-2013, 02:15 PM   #12
Mr_Gone
The Lejund!
Mr_Gone's Avatar
Oddometer: 8,641
My $0.02
I own an FJR and I've spent a day on a K1600. So I'm biased toward the FJR, and have only limited experience with the K1600.
If I were going to do 600-700 miles days, or rack up a ton of miles per year on longer trips, I'd take the BMW. Or if I was riding with a passenger, because the BMW seat is better, overall, IMHO.
For anything else (a couple long trips per year, weekend rides, commuting, buzzing around town), I'll take the FJR. As far as handling, the FJR is very capable in the twisties. Not CBR1000 capable, but it will take corners at just about whatever speed you dare.
Hope this helps.
Mr_Gone is online now   Reply With Quote
Old 04-09-2013, 05:50 PM   #13
roadstar
roadstar's Avatar
Oddometer: 362
Hope this helps.
If you go to the Iron butt results , you will see that the FJR is a super popular bike to do long distance on (one also won the 2011 IBR). It`s all in the setup & i`m pretty sure non are even close to stock. The K1600GT is too new to tell if it will be a reliable LD ride. Also alot of K1600GT owners are buying GTL handle bars to help with the reach ($800 bucks for the bars) Ken Meese has a GTL with about 30K miles on it & i`m sure he will do the 2013 IBR with it.
IBA # 47424
roadstar screwed with this post 04-09-2013 at 05:56 PM
Old 04-09-2013, 06:20 PM   #14
BalancePoint
Mucker
BalancePoint's Avatar
Oddometer: 217
I've owned neither bike. I have owned BMWs and while I loved them, my experience tells me this guy is giving you excellent advice.
07 Honda ST1300A
07 Triumph Scrambler
Experience is something you don't get until just after you needed it.
BalancePoint is offline   Reply With Quote
Old 04-09-2013, 06:38 PM   #15
GeoAggie OP
GeoAggie's Avatar
Oddometer: 271
I appreciate all of the advice so far. In terms of maintenance, I have had absolutely zero problems with BMW's in ~20 years of riding. So, that's simply not a factor for me. Value though is a different issue.
My one experience on the FJR was a 2nd generation model and it seemed to be stable but slow to turn in. The GT was easy to turn and remarkably agile for its weight but I have not had the luxury to ride the new FJR model or ride these two sport tourers back to back. GB's perspective is very interesting and much appreciated.
Jeff
Times are GMT -7.   It's 04:16 AM.
