Old 04-10-2013, 02:22 AM   #1
Travis28715 OP
Travis28715's Avatar
Oddometer: 31
inexpensive Motorcycle GPS (Garmin Quest 2)
I was thumbing through e-bay and found water-resistant Garmin GPS called Quest 2s for less than $100. Has anyone used these on their bikes that would like to give their thoughts on them? I found 2 with ram mounts for $150. Seems to good to be true.
Travis28715 is offline   Reply With Quote
Old 04-10-2013, 05:44 AM   #2
perterra
perterra's Avatar
Oddometer: 7,400
Thats getting pretty old I think. I wouldnt, my problem with my old streetpilot III was Garmin didnt support it with updates and when my old laptop running windows 2000 died I could no longer connect it.
My Father was my maker. Poverty was my maker. Distrust was my maker. I have met them all my life.
IBA 22425
perterra is offline   Reply With Quote
Old 04-10-2013, 07:21 AM   #3
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,280
I have one of the Quest 2s... For an older GPS it still carries a lot of features... The supplied built in road maps have pretty good detail, everything is in color and you have some room to add mapsource maps ... It does offer voice navigation ... It isn't the fastest GPS compared to the newer generation stuff but you can speed it up a bit by turning off some of the region maps you won't be using... It's not a large unit with about a 2"x3" screen but because of that you have more mounting options... You can no longer get map updates for the built in maps but they are not that far out with the last update being 2010 or 2011... You can load the newer mapsource maps in to the alternate map option but not too many as it has a limited amount of storage .. The biggest down with this unit is that it does not store tracks, only routes...
Hope this helps...
gunnerbuck is offline   Reply With Quote
Old 04-10-2013, 08:39 AM   #4
itsatdm
itsatdm's Avatar
Oddometer: 4,938
Ditto the above. The screen is really too small for this old man's eyes, which require a stop sometimes. The biggest issue is with the antenna. It is in the folding lid of the unit and the connections break. I am working on my 3rd one because of it. A simple repair to replace one, but Garmin insists on sending it in and charges accordingly.
Finally I just bought a remote antenna and it works better.
Old 04-12-2013, 09:01 AM   #5
Travis28715 OP
Oddometer: 31
Thanks for the replies
Bought the pair. I figure two ram mounts, hard wired cradles and external antenna are worth the price. Just need something to get me back in known area when I get lost (often).
Old 04-12-2013, 09:16 AM   #6
crypto666
Oddometer: 1,352
If you have a Android phone, you can't beat the Back Country GPS app. It has replaced my Garmins and my Trimble GPSs for everything but submeter data logging.
$10 will do more than the $400 Garmins and is easier to use than the $600-$6000 Trimbles.
crypto666 is offline   Reply With Quote
Old 04-12-2013, 09:32 AM   #7
Blue&Yellow
but orange inside...
Blue&Yellow's Avatar
Oddometer: 754
+1
Just get a protective casing that fits your phone and you're good to go.
Just look at taxis - most don't buy Garmins anymore. They buy Ipads and they get 4 times the screen size for about the same price. And they can surf the net and watch the news on it while sipping coffee in the taxi que.
Blue&Yellow is offline   Reply With Quote
Old 04-12-2013, 10:08 AM   #8
crypto666
Oddometer: 1,352
Originally Posted by Blue&Yellow View Post
+1
Pelican makes a clear case for the I-phone that works with the droids until you need to charge it. I had to modify mine so that I could plug the usb cable in while its in the case. I simply epoxied a cut down .300 ultra mag case to make a pocket for the usb cable to reside. A picture would help, but be creative and you will find a solution.
http://www.pelicancases.com/i1015-p/i1015.htm
Old 04-12-2013, 10:49 AM   #9
my6
my6's Avatar
Oddometer: 380
I'm gonna be mounting my SP/III in place of my speedo unit in the near future on my "L". Yea it's old and Garmin doesn't offer anymore updates but the way I see it the dirt roads I ride on are as old as, well, DIRT and it's expendable in the event of a catastrophic breakage.
Check your Six
04/625 SXC
98/200/MXC
my6 is offline   Reply With Quote
Times are GMT -7.   It's 07:28 PM.
