Old 04-10-2013, 12:14 PM   #1
PRJKTM OP
Oddometer: 63
990 Adventure Seized rear top case nuts
Hello
I've just bought a top case for my 990 Adventure.
I went to fit it tonight and the nuts holding on the back plate are seized solid.
If I pull any harder they will definitely strip the allen head.
I've tried WD40 and heating and no change.
Any suggestions really welcome
PRJKTM is offline   Reply With Quote
Old 04-10-2013, 01:03 PM   #2
Mr_Snips
Husky BRAAAAAAAAP!
Mr_Snips's Avatar
Oddometer: 352
Pb blaster or another good penetrating oil. Start there
Originally Posted by Reprobate
Familiar. My stock response: "Most people die in bed. So, where do you sleep?"
Mr_Snips is offline   Reply With Quote
Old 04-10-2013, 02:49 PM   #3
ElRod
4<2
ElRod's Avatar
Oddometer: 293
Try a handheld impact driver, the kind you strike with a hammer. Mine is a 3/8" square drive that an allen socket is placed into. Be sure to grind or cut off only what is needed of the hex portion so no driving force is lost to twisting.
ElRod is offline   Reply With Quote
Old 04-10-2013, 03:21 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,997
These bolts run through the aluminum subframe.
So you can spray them or/and heat them from underneath. The reason they get too difficult is they are sprayed with mud from the rear wheel. Try cleaning them with a wire brush
Hope that helps.
Cheers.
gefr is online now   Reply With Quote
Old 04-10-2013, 07:46 PM   #5
petdav
Oddometer: 83
Never-seeze on these bolts
When you finally get them out - I suggest using Never-seeze on the threads instead of Loctite. Also on Chain adjuster bolts to prevent the same thing happening
petdav is offline   Reply With Quote
Old 04-11-2013, 02:33 AM   #6
PRJKTM OP
Oddometer: 63
Done it...soaked in WD40 overnight and used a more substantial allen key with handle.....thanks all
Old 04-11-2013, 01:13 PM   #7
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,922
The Anti_seize is simply the best thing you can do for those bolts, any bolt that is steel going in AL for that matter should be treated with it.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 04-11-2013, 03:23 PM   #8
ElRod
4<2
ElRod's Avatar
Oddometer: 293
The threads going into the tail of the frame are steel to steel and I use a drop of permatex blue there. However, the underside of those flat head socket cap screws need the anti-sieze where it goes steel to aluminum.
Times are GMT -7.   It's 11:02 AM.
