Old 05-11-2013, 11:11 AM   #16
Scootern29
Scootern29's Avatar
Oddometer: 518
I'm just gonna throw this out there. Maybe the ignition is going bad. Have you checked for spark right after it dies out? I had this happen once with a Husky. Same syptoms, got hot and would die, and then cooled off it would start and run till it warmed up again.
Scootern29 is offline   Reply With Quote
Old 05-11-2013, 01:08 PM   #17
sam2 OP
Oddometer: 31
OK so I just tried to kick it over and it fired up for 1 to10 Seconds a few,times, but when it did it smoked ridiculously (and not just the normal amount of smoke, I'm talking clouds) and I had to repeatedly crank on the throttle to even keep it running for 10 seconds of smokiness then it would die out again.
sam2 is offline   Reply With Quote
Old 05-11-2013, 01:31 PM   #18
daviethebiker
Oddometer: 52
I would check the coil. I don't have a manual for the numbers but it appears like the sparkplug isn't getting enough juice to produce a strong spark.
daviethebiker is offline   Reply With Quote
Old 05-11-2013, 01:33 PM   #19
Scootern29
Scootern29's Avatar
Oddometer: 518
I would fathom the wet side clutch seal went and you are sucking tranny oil through it.
Old 05-13-2013, 05:59 AM   #20
wfrpalm
wfrpalm's Avatar
Oddometer: 128
Sounds right to me.
wfrpalm is offline   Reply With Quote
Old 05-13-2013, 11:30 AM   #21
sam2 OP
Oddometer: 31
So the motor has to be split to replace that seal right? Is there a specific tool I should get to split the cases, I have heard that the husky cases are easy to damage while splitting?? I guess while im doing all of this i should replace the other seals and clutch plates, as im sure none of that has been done in the last couple of decades. Is there anything else I should do while I'm in there? I really wanna go through everything this time as its a 30 year old bike and I dont think its had more than a top end replaced.
Times are GMT -7.   It's 05:39 AM.
