Old 04-22-2013, 12:53 PM   #331
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,807
Originally Posted by corndog67 View Post
Pardon the question, but do those change the way the bike handles? Do they make it top heavy? Are they affected by wind gusts?
No more than stock.
The weight distribution is changed by both the rider position (higher and further back) and any luggage you may or may not add, that you should be able to tune out with the preload.
I have both clip-ons and handlebars for my Speed Triple, I used to swap it back and forth depending on if I was commuting or in moutains (or at the track) that week.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 04-22-2013, 01:26 PM   #332
Dalmatino
Dalmatino's Avatar
Oddometer: 322
When the crossplane crank R1 came out i was all gung-ho to buy one so I went for a test ride. Could have had it out for few hours but brought it back in 20min. Sounded good but thats about all. Would never trade it for the 05-06 gixxer. It did not stack up in any department. Might be a good tractible motor but it was boring as shit.
All you guys arguing tha all liter bikes are fast and torque enough...You're right to a point but obviously you havent riden to many different makes and year spreads to realy see the diference. The difference is the ability to short shift out of corners and have the most umph with least amount of consequances....05-06 gixxer has that and the top end thats still amazing and neuteral handling and most comfy ergonomics. This is why it's still praised by many as favorite even amongst the latest.
Dalmatino is offline   Reply With Quote
Old 04-22-2013, 01:29 PM   #333
corndog67
Oddometer: 1,281
MY KTM 950 has enough grunt coming out of turns to spin up the back wheel and wheelie at the same time, but it doesn't have the top end rush of the big bore 1000s. They are all really similar, same ice cream, different flavor. I don't think stripple can go wrong with any of them. Whatever is the best deal.
corndog67 is offline   Reply With Quote
Old 04-22-2013, 01:43 PM   #334
cls
Oddometer: 1,134
Originally Posted by Tripped1 View Post
I posted dynos from both bikes, and I would bet money that you would NEED a dyno to tell the difference.
That, and it simply doesn't matter, any deficiency in torque can be fixed with the final drive, these aren't direct drive machines, the torque is multiplied three different times in the drive line.
I wasn't referencing any particular bikes, just the general application. Changing gearing changes revs, time in gear, etc. I like torque-rich, low-mid rev powerful engines. I also like tall gearing for relaxed cruising on the highway. Changes are, well...changes. Neither good or bad in and of themselves.
cls is offline   Reply With Quote
Old 04-22-2013, 03:51 PM   #335
joexr
Oddometer: 3,773
Originally Posted by rico2072 View Post
Didn't notice you were down here in Fl.
Small world.
I'm in the TSB site too.
What city you in?
Old 04-22-2013, 04:15 PM   #336
rico2072
rico2072's Avatar
Oddometer: 320
Originally Posted by Dismount View Post
Those are not hard bags. Those are warp nacelles.
They been called worse! LOL
Just kidding, but I actually had to look up what that was! LOL
"Beware of the lollipop of mediocrity. One lick and you'll suck forever!"Brian Wilson
rico2072 is offline   Reply With Quote
Old 04-22-2013, 04:17 PM   #337
rico2072
rico2072's Avatar
Oddometer: 320
I haven't had anything in there as weight is concerned. I figured it wouldn't be as bad as riding with my GF on the back, probably better since I don't expect to have more than 60 lbs total. Also, the wind turbulence was not even remotely noticeable.
Old 04-22-2013, 04:27 PM   #338
rico2072
rico2072's Avatar
Oddometer: 320
Originally Posted by stripple View Post
Rico,
That bike is a thing of beauty! I'm assuming that you went with convertibars on your bike? What kind of reach increase do you get all the way up?
I really like that bracket idea also.
Thanks for showing us your machine. That's the kind of machine thatbim dreaming about...
Haven't put the bars on yet. Waiting to make the custom spacer to lift the fairing. Should be soon though. Plus I will probably need extended brake lines. Another thing, on the R1 the steering damper mounts on the handle bar and frame, so you also need to buy an aftermarket fork clamp to mount the damper. I will be taking lots of pictures pictures when I get around to put it together.
Old 04-22-2013, 04:35 PM   #339
rico2072
rico2072's Avatar
Oddometer: 320
I would agree with you, but me personally, the 05 GSXR 1000 had too short distance from the seat to the pegs for me to sit comfortable.......hell of an engine thou.
Old 04-22-2013, 04:37 PM   #340
rico2072
rico2072's Avatar
Oddometer: 320
Originally Posted by joexr View Post
What city you in?
Tampa, near the casino. Ride out every Sunday, too much work the rest of the week.
I'm always on www.tampasportbikes.com
RICO on the board.
Old 04-22-2013, 07:30 PM   #341
single
Oddometer: 121
O hell, not this shit again!!!!
Your points are appreciated Single. But let me sum it up like this;
My DD car is set up to make big power. It has very stiff suspension to grab the road hard and stick. Because of this, it is not as comfortable or easy or user friendly as it would be in stock form or compared to an Accord or any SUV. But I put up with because IT'S WHAT I PREFER.
I don't want a VFR/Sprint/FJR/ST. I appreciate the merits of those machines, and I'll probably go back to them in the future after I've scratched this itch.
My car isn't dangerous unless I put my foot down, and my SS bike that I set up for travel won't be dangerous either unless I grab a handful.
I see what you're saying, and no disrespect intended, but it doesn't matter. It's about what I want to do. I'm not a kid and I have a lot of experience on two wheels.
This argument could go on forever, so let's put it to bed. It's my bike, my idea. It's very possible that I'll do this and say, "that sucked, Single was right!"
Oh well, I'm sure that I'll have fun in the process. And honestly, I really, really like fun. That's how I roll.
Honestly I'm not sure why you are so upset. I'm simply posting my experiences and having a discussion with a few other members about very specific aspects of superbike ownership. You certainly don't need to justify to me why you want a motorcycle and I'm not trying to be the ultimate adjudicator of who buys what. If my responses aren't helpful for you, then just ignore them, they may benefit other people in your shoes who have different priorities and are considering buying a superbike.
Cheers
single is offline   Reply With Quote
Old 04-22-2013, 07:46 PM   #342
ECN-ROL
ECN-ROL's Avatar
Oddometer: 133
t.
You can have my GSXR1000 for $6500! :-)
ECN-ROL screwed with this post 04-22-2013 at 08:07 PM
ECN-ROL is offline   Reply With Quote
Old 04-22-2013, 07:51 PM   #343
stripple OP
Runnin' Hard
stripple's Avatar
Oddometer: 604
Cheers
My man, I'm not upset. I suppose that I'm just trying to head off another 7 page argument.
And, I suppose that I take issue a bit with people saying that it's silly to use a SS for this purpose. As I write that I realize that it actually is. But, I don't so much like being told what's best for me. I understand where you're coming from thought. It's all good.
“Who is the happier man, he who has braved the storm of life and lived or he who has stayed securely on shore and merely existed?” Hunter S. Thompson
stripple is offline   Reply With Quote
Old 04-22-2013, 07:55 PM   #344
stripple OP
Runnin' Hard
stripple's Avatar
Oddometer: 604
We should talk.
First I need to know where "internet heaven" is...
stripple screwed with this post 04-22-2013 at 10:49 PM
Old 04-22-2013, 09:54 PM   #345
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 7,807
You aren't going to get V-twin like tall, the primary is usually shorter and the transmission will be closer ration normally, mainly because your operating range from a normal big bore twin to a 1000cc I-4 is possibly 30-40%, the red lines on the I-4s are frequently in the neighborhood of 12,000.
I was more commenting on what changing the bike does to the chassis, all of the super sports are front end biased weightwise, this is by design, it helps to keep the front on the ground under throttle. When the rider sits straight up on the bike is IS more likely to try to walk around. Luggage is really neither hear nor there, they actually handle faster as you add weight high on the bike, it less effect than a passenger, unless your passenger is a 6 year old.
The pegs can be dropped, GSXRs are actually fairly forgiving as far as seat to peg clearance usually. You want no seat to peg distance try a R6 or 675 Daytona. On my Daytona my knees are actually higher than my elbows when I tuck in....I think my pegs are an inch and a half taller than stock (its a track bitch)
Tripped1 screwed with this post 04-22-2013 at 09:59 PM
Times are GMT -7.   It's 04:35 AM.
