Old 04-11-2013, 06:12 PM   #1
clicheche OP
clicheche's Avatar
Oddometer: 72
yamaha dt175cc enduro
i have a pretty bad gearbox oil leak. probably the crank seals?
is there a decent tutorial on the site as to replacing these?
i've tried searching.
-brent
(first they ignore you, then they laugh at you, then they fight you, then you win)
clicheche is offline   Reply With Quote
Old 04-11-2013, 06:32 PM   #2
baloneyskin daddy
bikaholic
Oddometer: 2,162
Theres only one crank seal that could leak trans oil and it would leak into the crankcase and smoke like hell when running. If its leaking onto the ground its probably the shift shaft seal ,countershaft seal or gasket on the drainplug .
baloneyskin daddy is offline   Reply With Quote
Old 04-11-2013, 10:04 PM   #3
clicheche OP
clicheche's Avatar
Oddometer: 72
what is, and where is the countershaft and seal?
i reckon i know the shift shaft seal.
-brent
Old 04-12-2013, 03:14 AM   #4
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,283
countershaft seal is behind the sprocket.
both the shift shaft and countershaft seals are easy to fix.
there is also a shifter cover on the early dt175 (1974-1976) (held on with four bolts behind shifter) - it has a rubber o-ring around it that could leak, but that's doubtful.. what year is your dt175?
it could also leak between the crankcase halves. or a cracked case could leak... or even the clutch cover could leak.
current bikes
stainlesscycle is offline   Reply With Quote
Old 04-12-2013, 08:26 AM   #5
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 1,560
CS seal would not have pooled oil behind it, little higher than the level. It would leak while running. Likely shifter seal, or clutch push rod as well.
As stated, easy to replace in situ. Just did it on my RT1 plus the crank seals as well.
Do you go to the Yamahaenduro.com website. Dedicated forum for these old bikes there.
2006 HD 1200C, 2006 Tri Scrambler, 2001 Duc M900, 2001 Hon XR650L, 1994 HD Heritage, 1989 Hon Hawk GT, 1978 Hon CB750K / sidecar, 1977 Guzzi 850 LeMans, 1976 Hon CB750K, 1965 Hon 305 Dream, 1973 Nort 850 Commando, 1971 Tri Trophy 650, 1970 Hon Trail 90, 1970 Tri Tiger 650, 1973 Hon Z50, 1984 Yam Virago 1000, 1981 Hon Passport 70, 1970 Suz T250, 1971 Yam RT1 360, 1965 Hon CT200
lrutt is offline   Reply With Quote
Old 04-14-2013, 10:31 AM   #6
clicheche OP
clicheche's Avatar
Oddometer: 72
thanks for the responses.
i have joined the yahamaenduro site as well.
this one is phenomenal though!
i am going to replace both the shift shaft and crankshaft seals.
the year of my bike is a 1980 dt175cc
so i don't know if it will have the o-ring you speak of, though i will look.
(ps:i really hope this bike runs better now that i've got por15 all over my hands from lining the incredibly rusted gas tank. looks to have done a pretty good job. thousands upon thousands of times better shape than it was prior.)
on the other side of the bike, is there a gasket for the gearbox cover or anything? that looks like it could potentially be leaking as well.
thanks a ton for the replies folks!
-brent
Old 04-15-2013, 03:47 AM   #7
stainlesscycle
Oddometer: 2,283
you do not have a separate shifter cover, so no o-ring.
clean the motor, and look for where it's weeping..
current bikes
Old 04-16-2013, 10:32 PM   #8
clicheche OP
clicheche's Avatar
Oddometer: 72
pretty sure its leaking from the shift shaft. though i'll be replacing the crank shaft seal as well. is there a particular tool to loosen the crank gear?
and you're right, i don't see a separate cover... just one.
-brent
Old 04-17-2013, 09:56 PM   #9
clicheche OP
clicheche's Avatar
Oddometer: 72
hi ya.
so i'm wondering if i have to remove a philips bolt right next to the shift shaft to remove it or not...
also, do i have to disconnect the chain in order to loosen the crankshaft?
or just loosen the crankshaft?
1980 yamaha enduro 175cc
-brent
Old 04-17-2013, 10:02 PM   #10
clicheche OP
clicheche's Avatar
Oddometer: 72
looks like i don't remove the shaft... duh. just a ring and washer around it? to gain access to the seal?
-brent
Old 04-18-2013, 02:44 AM   #11
stainlesscycle
Oddometer: 2,283
do not need to remove shaft. if you want to remove shaft, you need to pull clutch cover, remove clutch basket, etc, because selector end of shaft is behind it.
to replace shift shaft seal, just pull the shifter lever off and remove replace seal. i do not believe the later models had the snap ring/washer/rubber boot external to the seal. the early ones did.
current bikes
Old 04-18-2013, 02:45 AM   #12
stainlesscycle
Oddometer: 2,283
huh? loosen the crankshaft? i'm assuming this is a typo/misspoke/etc...
you mean countershaft seal? remove rear wheel, move chain off front sprocket. bend lock tab on frt sprocket. remove nut. remove sprocket. remove/replace seal. you may want to bend locktab and loosen frt sprocket nut before you remove wheel/chain so you have something to hold the frt sprocket from spinning..
there is a bushing the countershaft seal rides on. you may want to replace, or at least flip it around if the seal has worn a big groove in it.
current bikes
Old 04-18-2013, 10:15 PM   #13
clicheche OP
clicheche's Avatar
Oddometer: 72
well damn it. so its the countershaft seal that is on the same side as the shift shaft seal? that's brutal. i ordered a crankshaft seal and a shift shaft seal. thought to be on the same (left) side of the bike.
would i have to drain the gear oil when changing either seal? maybe just for the shift shaft seal? not the 'countershaft' seal?
-brent
Old 04-18-2013, 10:19 PM   #14
clicheche OP
clicheche's Avatar
Oddometer: 72
well here's hoping. the dude at blackfoot motosports here in calgary said, 'so the left hand side of the bike? those two seals?' so hopefully he just ignored my blunder of calling it the crankshaft seal... is there a crankshaft seal on the bike? or am i just spouting weird words?
-brent
Old 04-19-2013, 07:38 AM   #15
mtothef
Oddometer: 401
shop manual
please don't take this as me being a dick, but...
maybe you should get a repair manual for the bike? that would, at the very least, help you identify the parts you are talking about, and give you some reference points as to what all is going on with the bike and what people on this site giving you advice are speaking about. seriously, every single bike i ever tear into at some point or another has some moment where i am elbow deep in engine parts saying to myself "what the hell is this?" moments like those, a shop manual can be worth its weight in gold. other times, shop manuals can also be just obscure enough to frustrate the hell out of you, but most of the time they are a very solid investment.
re the seals you are talking about, the shop guy was right - "the two seals on the left side of the bike." both of them can be replaced pretty easily, as has already been mentioned. if you are careful, you don't even have to drain the oil, just lay the bike on the right hand side and work on it there. there are also crankshaft seals, one on either side of the engine, they serve to keep the engine oil OUT of the crankcase, which is itself lubricated by the premix or autolube oil. they do need periodic replacement, and usually this involves tearing the engine almost all the way apart. they are in no way related to why your gearbox oil is appearing outside the engine instead of inside where it belongs.
mtothef is offline   Reply With Quote
Times are GMT -7.   It's 05:07 PM.
