View Results: What is your Favorite BumpStick?
I have a 296, no reason to have any other 4 26.67%
I have a 308, and It's a kinda MAGIC! 2 13.33%
I have a 320 SYMMETRIC, Love it! 1 6.67%
I have a 320 ASSYMETRIC (IE Siebenrock, MI, et al), It's the Shiznit! 4 26.67%
I have a 324, It's the Cat's Meow! 0 0%
I have a 330, why would I want anything else! 0 0%
I have a 332, I am in Nirvana! 0 0%
I have a 336, It's the Bee's Knees! 5 33.33%
I have a 340, and it's the Bomb! 0 0%
I have a 344, and it's a Stairway to Heaven! 0 0%
Multiple Choice Poll. Voters: 15. You may not vote on this poll
Old 04-13-2013, 08:55 PM   #16
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Deleted -- Apparently of little Interest to anyone.
Sorry for wasting your time
<<This is my Airhead, there are many like it, but this one is mine>>
My "Orange Snappy Club" Membership Photo
Les_Garten screwed with this post 04-15-2013 at 10:39 PM
Les_Garten is offline   Reply With Quote
Old 04-13-2013, 09:16 PM   #17
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,256
[QUOTE=Les_Garten;21180672]
Originally Posted by Lornce View Post
I put this Andrews cam in my GSPD with good results. It's either a #2 or #3, can't recall exactly. The paperwork is burried somewhere in the basement of my "other place".
Thanx! Is the Andrews on the Right in the PIC?
Yes. It's got more lift and greater duration, though it's hard to tell until you realise it has a much smaller base circle than the stock 308 cam on the left.
Old 04-14-2013, 01:54 AM   #18
chasbmw
Oddometer: 2,354
Baseline dyno run
Baseline dyno run on a Slightly modified R100/7. The 2 lines show the difference between standard silencers and a set of Jim Cray's.
Charles
1971 Commando Fastback
Old 04-14-2013, 02:00 AM   #19
chasbmw
Oddometer: 2,354
Base run dyno run on r90/6, almost standard with high compression pistons. This bike has been fitted with 320 cam from motoren Israel, comparison dyno run will be made when engine run in.
Charles
Old 04-14-2013, 02:07 AM   #20
chasbmw
Oddometer: 2,354
Another earlier Jim Cray dyno showing the results of his standard stage 1 tuning package on a euro 82 RS engine.
This does not include camshaft changes, just porting, dual plugging, induction and squish band work. Note the very much fatter torque curve.
Charles
Old 04-14-2013, 02:10 AM   #21
chasbmw
Oddometer: 2,354
Image Links
IMG code
Update Link Options
Media Info
Seibenrock 1070 kit dyno runs, red at 26 degrees, blue at 28 degrees, dells, Seibenrock assymetrical cam, 40 mm straight through Jim Cray silencer, ported dual plugged, run taken after only 1200 miles
Charles
Old 04-14-2013, 02:14 AM   #22
ME 109
ME 109's Avatar
Oddometer: 3,143
I wouldn't have a clue what cam I have. It is stock, as far as I know.
It doesn't matter.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 04-14-2013, 03:15 AM   #23
ME 109
ME 109's Avatar
Oddometer: 3,143
It doesn't matter.
Edit, I forgot to vote so I went to the polling booth but I couldn't see a 'I wouldn't have a' box?
Old 04-14-2013, 09:14 AM   #24
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,256
Be interesting to know what's causing such a dramatic drop in torque right through the middle of the useful rev range.
Any thoughts.
What are the lift/duration specs on the "asymetrical" cam.
Originally Posted by chasbmw View Post
Image Links
IMG code
Update Link Options
Media Info
Old 04-14-2013, 11:32 AM   #25
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Old 04-14-2013, 11:34 AM   #26
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Les_Garten screwed with this post 04-15-2013 at 10:40 PM
Old 04-14-2013, 12:06 PM   #27
chasbmw
Oddometer: 2,354
Originally Posted by Les_Garten View Post
Hey CHASBMW, thanx for the graphs. On some of the GS's, that Torque dip was cured with exhaust changes. Has Jim Cray mentioned why this occurs on non GS's? Basically, what is the fix?
Is your 320 the Symmetric or Asymmetric version?
Les, my 1070 bike has a single crossover exhaust, with a proper 40mm diameter, this might have something to do with the dip, you can feel it on the 1070 bike, but then coming out of that dip is very nice. The 1070 has the assymetrical cam as supplied by Seibenrock for the 1070 kits. I never raised the issue with Jim.
The R90/6 has the non assymetrical cam 320 cam and it will be interesting to see the results, especially as with it's current set up the torque curve is almost straight.
Charles
Old 04-14-2013, 12:25 PM   #28
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Some General Material from my Cruisings
Les_Garten screwed with this post 04-15-2013 at 10:41 PM
Old 04-14-2013, 12:27 PM   #29
Les_Garten OP
Les_Garten's Avatar
Oddometer: 732
Old 04-15-2013, 02:19 AM   #30
chasbmw
Oddometer: 2,354
How do you like the Symmetrical 320 on the R90 compared to the 308 I assume you used to have in it?
I'm waiting to find out, bike should be running again this week, then after it is run in I will dyno test it on the same dyno as the base line test. This should give some idea of the changes that a cam swop can achieve.
Not definitive, but a better idea then "my bike with a XYZ cam revs like a MOFO and does 300 yard wheelies uphill in 4th gear"
The reason for using the 320 cam is that my R90/6 is one of the early small front seal engines and aftermarket Cam choice is limited to either the 320 or the 332. Rudi, one of the contributors to this forum said that he had had good experiences from this cam.
Charles
chasbmw screwed with this post 04-15-2013 at 02:27 AM
Times are GMT -7.   It's 07:19 AM.
