Old 05-01-2013, 06:25 PM   #46
Boxer Metal OP
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,506
Here is a picture of both rods.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Old 05-01-2013, 07:05 PM   #47
ME 109
ME 109's Avatar
Oddometer: 2,854
Nothing out of the ordinary to my eye bmweuro.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 05-01-2013, 07:29 PM   #48
Boxer Metal OP
Mad Scientist
Oddometer: 3,506
The left wrist pin slid out a little to easy and the right took a little persuading. The left rod small end is pretty beat up.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-01-2013, 07:37 PM   #49
Plaka
Brevis illi vita est
Oddometer: 4,612
What do the crank journals measure?
What does some plastigauge say about the big end clearance?
What does the small end measure? (you replace those bearings sometimes too.)
What do the pins measure?
What about the piston OD, cylinder and taper?
Bore ID, cylinder and taper?
Old 05-02-2013, 06:48 AM   #50
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,736
[IMG]https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-frc1/485543_527117007334126_1992627147_n.jpg[/snip]
Not bad-looking enough to be knocking. IMO.
Puzzling. Make some measurements.
--Bill
'73 R60/5 Toaster
Old 05-02-2013, 09:33 AM   #51
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,414
It looks like the problem was not rod bearings. Also, 30 psi at 1100 rpm and 70 psi at 3000 rpm is good oil pressure. Are you sure the problem is not pre-detonation knocking? How do the heads and pistons look - is there a lot of carbon? Any indication that the valves are contacting the piston (or carbon on the piston)? Could this be a piston slap problem? Now is the time to address any and all of these (somewhat unlikely) causes. Could this 'knock' be timing chain slap? Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 05-19-2013, 09:26 PM   #52
Boxer Metal OP
Mad Scientist
Oddometer: 3,506
I raised the needle position up one notch and now it runs a little rich and took it for a good ride today. The noise is back. So I have oil pressure, timing is correct, fuel mixture good.
I don't think it's the timing chain because you would here it at idle. I'm starting to wonder if there is something rattling under the tan or next to the starter.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-19-2013, 09:46 PM   #53
Plaka
Oddometer: 4,612
Did you measure up everything before you put it all back together?
Old 05-19-2013, 10:29 PM   #54
Boxer Metal OP
Mad Scientist
Oddometer: 3,506
The motor measured out like it had very low miles.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-19-2013, 10:40 PM   #55
Plaka
Oddometer: 4,612
Run a tank of high test. That will put detonation to bed.
Then work on making it knock at idle. If you can find a big deserted parking lot, try it without a helmet and bounce it around. You may well find something to your 'something rattling' theory.
Old 05-19-2013, 11:46 PM   #56
Boxer Metal OP
Mad Scientist
Oddometer: 3,506
I only run 91 octane and I have been riding it around the shop without a helmet for weeks trying to pin point it.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-20-2013, 01:01 AM   #57
Plaka
Oddometer: 4,612
Check plugs w/ magnifying glass for signs of detonation (typically the insulation is white with tiny beads of molten metal).
Unless you just want a shop bike, try a parking lot, a bumpy one.
Check the usual suspects: missing center stand bumpers, Ovalised shock bolts, loose subframe bolts, loose battery box bolts, any bolt on the front end, coil mounts, etc.
Old 05-20-2013, 02:47 AM   #58
chasbmw
Oddometer: 2,253
I don't know how old the bike is but, the original timing chain tensioner fitted to the single timing chains, used to make a bloody awful noise when worn, BMW later rejigged the design and the problem went away.
Charles
1971 Commando Fastback
Old 05-21-2013, 10:52 AM   #59
Boxer Metal OP
Mad Scientist
Oddometer: 3,506
Update.
I checked the jetting and 170 mains, 45 idle. I raised the needle one notch. Still runs fine and I can start it without the chokes on. I pulled the plugs and they look a little on the lean side. The motor is a 1976 R90/6 with 40mm Bings(odd combo).
Still trying to find the noise.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-21-2013, 10:59 AM   #60
chasbmw
Oddometer: 2,253
from another forum:
http://forum.bmw-club.org.uk/viewtopic.php?t=28150
Charles
Times are GMT -7.   It's 11:38 AM.
