Old 04-15-2013, 02:14 AM   #1
mike.l OP
mike.l's Avatar
Oddometer: 63
No low-fuel light after Facet pump Installation
Is it normal for the low-fuel warning light not to work after installing the Facet fuel pump?
mike.l is offline   Reply With Quote
Old 04-15-2013, 03:43 AM   #2
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,287
No. Did you reconnect the wire that goes into the left tank?
Orangecicle is online now   Reply With Quote
Old 04-15-2013, 06:27 AM   #3
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
+1
The connections to the left tank are the following:
fuel pump power, fuel level sensor.
Cheers.
Old 04-15-2013, 06:44 AM   #4
Orangecicle
On a "Quest"
Oddometer: 3,287
Cheers.
? He's putting on a Facet, which means this is a carbed 950. There is no fuel pump power line going to the left tank. The only electrical hookup on the left tank is the fuel level sensor.
Old 04-15-2013, 07:05 AM   #5
triplenickel
triplenickel's Avatar
Oddometer: 2,430
Maybe it's an SE?
07 SE
PG007
Old 04-15-2013, 07:59 AM   #6
Orangecicle
On a "Quest"
Oddometer: 3,287
Originally Posted by triplenickel View Post
Maybe it's an SE?
Oh, yep. Could be.
Old 04-15-2013, 08:38 AM   #7
mike.l OP
mike.l's Avatar
Oddometer: 63
Ah yeah sorry lads, it's a '05 carb'ed 950. The Odometer's sort of working ok, though It's not autmatically switching to TRIP F when fuel has gone into reserve + there's no warning light coming on.
Old 04-15-2013, 09:06 AM   #8
Orangecicle
On a "Quest"
Oddometer: 3,287
Check the wiring to the sensor. I have also heard that these sensors can eventually go bad.
Old 04-15-2013, 10:01 AM   #9
keener
Speed changes you.
keener's Avatar
Oddometer: 1,017
First of just check you have not plugged the fuel pump wires to the low fuel sensor plug. They have the same type of connectors.
If that was not the issue, I suspect it has nothing to do with the sensor. It has a very simple job to turn a switch on or off. So if your trip meter for low fuel comes up, that means the sensor is sending the signal correctly to the instrument panel.
I put my money on burnt LED light for low fuel, or faulty instrument panel.
You can bypass the sensor by connecting the two wire at fuel level sensor's plug (on the bike side of course) Brown and Brown-Red
04 ADV 950
keener is offline   Reply With Quote
Old 04-15-2013, 10:44 AM   #10
RedFrogTango
RedFrogTango's Avatar
Oddometer: 758
What is the low-fuel/reserve warning look like on an '07 990 adventure? I just bought the bike from another inmate and ran it out of gas on the way home. Should I have gotten a yellow warning light? Or is it more subtle than that (and something I probably did not see without my glasses).
Sorry if I sidetracked this thread, but I have yet to track down an owner;s manual.
Thanks, Mike.
RedFrogTango is online now   Reply With Quote
Old 04-15-2013, 10:51 AM   #11
sonoran
you already know
sonoran's Avatar
Oddometer: 25,679
There is a yellow LED indicator which will come on then then odometer will show "F" and the mileage accrued since low fuel threshold was reached. Typically this means you have somewhere between 25-50 miles remaining before running dry.
sonoran is offline   Reply With Quote
Old 04-15-2013, 01:14 PM   #12
RedFrogTango
Oddometer: 758
Thanks. That is what I figured. In my case, the yellow LED did not come on and I ran the tank dry. I guess I'll need to figure out if I have a loose wire or bad sensor.
Old 04-15-2013, 01:42 PM   #13
DirtyADV
DirtyADV's Avatar
Oddometer: 2,420
If it goes to Trip F automatically cant it be broken low fuel led? Will that light up with ignition on? Long winter so cant remember.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 04-15-2013, 02:19 PM   #14
RedFrogTango
Oddometer: 758
/Johan
The yellow LED on the panel lights up when the ignition is turned on. I don't recall if the trip meter went to Trip F - it may have and I did not notice. I wear reading glasses, but not while I'm on the bike. Hence, the Trip readout is a bit of a blur. And since this is a new bike for me (bought the day before), I did not know to look for Trip F. I was also in the middle of a single lane construction zone when this all happened so I was a bit distracted.
BTW - I don't have an owner's manual so I'm still trying to sort through the bike.
Old 04-15-2013, 03:29 PM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,178
http://www.ktm950.info/how/owners_ma...s_manuals.html
You can download them and in case opening needs a password, Katoom is your password.
Cheers
Times are GMT -7.   It's 06:47 AM.
