Old 06-29-2013, 10:52 AM   #31
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 822
22mm open end wrench & torque on the top nuts is 40nm
For the GS LC you actually need a 22mm open end wrench and the torque on the top nuts is 40nm & use blue loctite if you reuse the nuts. (This from my dealer's service dept. who've been great in providing this kind of info.)
Originally Posted by JM View Post
What he says.
Dropping the fork tube is super easy and simple. I just did my 2013 camhead and was really amazed how easy it was. There are several threads available to show you how. I think all you need is a 19mm open end wrench and a 14mm socket/ratchet.
I also had to reposition the throttle cable but you may not have that problem since you are doing the fly by wire thing.
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 06-29-2013, 11:10 AM   #32
fubar201
fubar201's Avatar
Oddometer: 256
Doc - Mine are on order and should arrive next week. Did you have any issues with cable length?
fubar201 is offline   Reply With Quote
Old 06-29-2013, 12:26 PM   #33
kindofblue
kindofblue's Avatar
Oddometer: 822
No but one side (can't remember which) is snug when you've got the bars all the way over. I'm going to drop the forks tomorrow and reroute the cables, just to be sure. That seems to be a relatively easy and quick task.
Doc Reid
Old 06-29-2013, 01:39 PM   #34
fubar201
fubar201's Avatar
Oddometer: 256
Yeah. Looks like mine are already a bit snug on the right so I'll plan on that too. I may see if I can snip some zip ties first tho.
Old 06-30-2013, 07:21 AM   #35
edpittenger
edpittenger's Avatar
Oddometer: 25
Wanna sell the risers from you old GS?
Originally Posted by oz97tj View Post
I attempted to install my Rox risers from my previous GS on the new one not knowing anout the change in diameter. Obviously they didntbwork. Good news is there appears to be plenty of excess wiring to allow risers without any modification.
I'm looking for a set for my '05 GS if you want to sell them. PM me if interested.
Beer is proof that God loves us and wants us to be happy. Benjamin Franklin
edpittenger is offline   Reply With Quote
Old 06-30-2013, 12:52 PM   #36
kindofblue
kindofblue's Avatar
Oddometer: 822
dropping the forks to relocate the cables
I had to buy a 22mm open end wrench to do this and also needed my wife to hold it (which keeps the fork from turning) while I loosened the nut on top of the forks. The same with putting the nut back on (w/blue loctite) and tightening it to 40nm w/the torque wrench. Maybe you could do this yourself. I didn't want to risk stripping the nut with the socket wrench.
Other than that, it really was easy and took no time at all. I cut the zip tie on the right cable but didn't need to cut the zip tie on the left.
I'm not sure you need to do this with the 40mm risers but in all likelihood will need to do it with the taller, adjustable Rox Risers that Chris is just finishing up the prototype. I'll be beta testing these too
Doc Reid
Old 06-30-2013, 01:04 PM   #37
oz97tj
oz97tj's Avatar
Oddometer: 819
Already sold them. Sorry.
'13 BMW 1200 GSW
'05 Honda ST1300
oz97tj is offline   Reply With Quote
Old 07-05-2013, 10:08 AM   #38
fubar201
fubar201's Avatar
Oddometer: 256
Installed my Rox *block* risers today. Fine quality and easy installation. They provide 35mm of rise over stock.
I did clip the front zip tie on the right. I'll watch it and decide later if I want to reroute the cables behind.
Old 07-06-2013, 06:18 AM   #39
kindofblue
kindofblue's Avatar
Oddometer: 822
riser height
Cool. I really like the prototype I've been using. I believe they're 40mm though.
Doc Reid
Old 07-06-2013, 02:47 PM   #40
fubar201
fubar201's Avatar
Oddometer: 256
That are indeed 40mm. Clearly mis-measured
Old 07-06-2013, 03:39 PM   #41
paco fernandez
Mexico
paco fernandez's Avatar
Oddometer: 64
Touratech.
Enviado desde mi iPad con Tapatalk HD
paco fernandez is offline   Reply With Quote
Old 07-06-2013, 04:56 PM   #42
fubar201
fubar201's Avatar
Oddometer: 256
Rox 40mm block risers.
Old 08-13-2013, 01:23 PM   #43
RoxStuff
Oddometer: 52
ROX SPEED FX 2012 BMW LC 2" Pivoting riser
Hey All,
Its been a bit since I have laid some tracks down on this thread so I thought I would give you an update. The LC riser R&D is complete after spending the weekend in Salem (MOA) with the Prototypes we designed. The prototypes were 2.25" in height, I have changed that to 2.125" for the final design. BMW chose to bump up the diameter of the stock clamps and handle bars to 1.25" diameter on the 2012 LC. It is NOT the same as previous GS1200 models which are 1-1/8" dia. or 7/8" dia. depending on the year and model. Hope that answers the questions being asked here.
We also have the solution for the cables. I have pics of what we did which will be in the instructions provided with the package. We did move the right side cables to the outside of the triple clamp. there is a factory placed zip tie hole on the shroud support on the right side that works perfectly for retaining the brake line and electrical lines running from the right handlebar controls. Zip ties were cut as far back on all cables (right and left controls) as we could. We loosed the clutch lever bracket and moved it inboard on the handle bar 1/8"-3/16" which gave us enough slack/play in the line to not have to move it outside the triple tree. I prefer that move anyways as I like to have my pointer and index finger resting in the elbow of the clutch lever vs the upper arm.
here is a 3D model of the final design coming off the machine centers this week. My hope NOW is to have product available in two weeks time. Thanks for your patience.
Chris~Rox
RoxStuff is offline   Reply With Quote
Old 08-13-2013, 01:31 PM   #44
RoxStuff
Oddometer: 52
ROX SPEED FX 2012 BMW LC 2" Pivoting riser LC
Right side cable routing pic. Outside the triple tree and zip tied to the OEM provided hole in the subframe.
https://dl.dropboxusercontent.com/u/...4/IMG_6908.JPG
Old 08-13-2013, 02:14 PM   #45
kindofblue
kindofblue's Avatar
Oddometer: 822
block vs. adjustable risers
As the beta tester for Chris and Rox I can testify that the adjustable risers are more comfy than the non-adjustable, block risers. For me, at least. (I'm 6'4" w/34" inseam.)
I was in Salem and helped Chris figure out whether the adjustable risers were going to work or not. We ended up installing the adjustable risers on the demo GS LC that Adventure Designs had there to show off the products they were offering.
Doc Reid
Times are GMT -7.   It's 02:54 AM.
