Old 09-19-2013, 08:15 AM   #61
rstott
Oddometer: 8
Got my risers yesterday. I had to move both RH and LH cables outside of the tree. They look great and the bars will now be in a better position for me. I am 6ft with a RDL seat which sits me a little higher.
rstott is offline   Reply With Quote
Old 09-20-2013, 02:07 PM   #62
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
I'm installing mine and have moved both sides outside the triple tree. Right side brake hose seems the become somewhat pinched or doubled up when at full right lock. The pinch is right where the hoses come out from under the tank. Anybody else have that?
Got places to do and things to be.
'14 1200 GSA
seatec is online now   Reply With Quote
Old 09-20-2013, 07:51 PM   #63
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,467
When I put my Wunderlich up and back risers on the bike I tried moving the brake line just to see how much of a difference. It what you are reporting. No way would I ride the bike that way. Luckily I didn't need to as the lines are JUST long enough for my risers.
marchyman is offline   Reply With Quote
Old 09-20-2013, 08:21 PM   #64
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
Unless there is a better way to do it I won't ride that way.
'14 1200 GSA
Old 09-21-2013, 05:57 AM   #65
kindofblue
Ride it like you stole it
kindofblue's Avatar
Oddometer: 830
I have the 40mm block Rox risers on my GS LC. Chris Olin of Rox and I worked on the installation at the MOA rally and concluded that the right brake line should be outside of the forks but also zip tied to the frame. There's a hole in the frame there just right for a zip tie.
I've got a set of his adjustable risers now but haven't had the time to install them. I think they may go on with the cables inside the forks.
Doc Reid
Wondering about your drinking? www.drinkerscheckup.com
Get saddlesore when riding? Check these shorts out
kindofblue is offline   Reply With Quote
Old 09-21-2013, 01:16 PM   #66
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
How did you tighten the riser up to the tree? I only have regular torx socket and that won't work. No clearance
'14 1200 GSA
seatec screwed with this post 09-21-2013 at 02:44 PM
Old 09-21-2013, 06:04 PM   #67
fubar201
fubar201's Avatar
Oddometer: 256
No room for what? I easily tightened mine.
fubar201 is offline   Reply With Quote
Old 09-21-2013, 06:53 PM   #68
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
You must have yours pivoted pretty far away or towards you to to have plenty of room to use a torx driver. I have mine pivoted almost straight up so I don't have any room.
'14 1200 GSA
Old 09-23-2013, 07:14 AM   #69
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
See my problem?!
'14 1200 GSA
Old 09-23-2013, 07:42 AM   #70
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,929
See my problem?!
Show me a photo form the side. I am betting a low profile torx would do it.
Jim
Old 09-23-2013, 09:29 AM   #71
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
I ordered a set of torx wrenches that are short enough the clear the rox risers
'14 1200 GSA
Old 09-23-2013, 04:13 PM   #72
seatec
Dutch Transplant
seatec's Avatar
Oddometer: 809
'14 1200 GSA
Old 09-23-2013, 06:34 PM   #73
JimVonBaden
"Cool" Aid!
Oddometer: 52,929
Looks basically like mine. Move the bars back and tighten the front bolts until you can barely knock the bars forward into place. Then tighten the rear ones using the Torx at an angle as snugly as you can get them without slipping the Torx. This will be more than tight enough.
Check this out: http://www.advrider.com/forums/showthread.php?t=243096
Jim
Old 09-24-2013, 06:56 AM   #74
Voz
Voz's Avatar
Oddometer: 484
Got my pivoting risers today. Fitted to my LC but no test ride yet. The pulling on the cables especially the brake cable is worrying.
I have them tilted towards me with just enough room to properly socket tighten and the handlebars are tilted in a little more inboard. The hand guard to screen gap is a little wider so the bars are about the same distance from me as OEM.
I have removed the cable tie from the brake & data cable on the right side and I think it is ok. Will not be able to come any more inboard though without re routing the cables on both sides. Should be ok.
Looking fwd to test rides and adjustments. I am pretty sure I will be clearing a lot more car mirrors now in the daily traffic filtering.
Sydney, Australia
2013 R1200 GSW Red - Blown Engine & Gearbox (clutch basket nut issue) - AUG 14
2015 R1200 GSW White - NOV 14
Voz is offline   Reply With Quote
Old 09-24-2013, 08:57 AM   #75
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,048
You can get ball-end torx bits and L wrenches that let you get in at an angle.
Times are GMT -7.   It's 07:38 AM.
