Old 04-15-2013, 10:13 AM   #1
950slider OP
Oddometer: 118
Bluhduh Oil Change OUCH!
Doing an oil change on my '04 Adventure and found 4 roller bearings (2.0 X 4.5mm) and a partially mangled bearing cage attached to my magnetic drain plug...looks like the some of the cage pieces found their way to the filter screen above the check valve screen in the oil tank, and some bits landed on the flat screen below the clutch cover.
Any ideas where those puppies came from?
Bike sounds fine before and after the oil change, shifts like normal, but a touch cautious about driving it until I can locate where those pieces 'fell' from...
Looking through parts fiche and not seeing it...anyone want to chime in?
950slider is offline   Reply With Quote
Old 04-15-2013, 10:21 AM   #2
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 3,149
Riding it like that is asking for trouble.
Orangecicle is online now   Reply With Quote
Old 04-15-2013, 11:00 AM   #3
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,849
My condolences on your loss.
2011 White 990 Adv S
2014 500EXC Black
FakeName is online now   Reply With Quote
Old 04-15-2013, 11:18 AM   #4
Leodis41
I wanna Orange one!!
Leodis41's Avatar
Oddometer: 65
Looking at the schematic, there is no way it can get from the engine to the oil tank, there is a filter screen before the scavenger pump and then there is the pumps itself. Cannot see how the bits could get through there to the oil tank.
Pictures of the bits would help to try and id the bearing, only bearing that springs to mind is the top cam gear bearing, I suppose if that had collapsed that could explain the bits if the sump, but not the oil tank.
Sorry can't help further.
Leodis41 is online now   Reply With Quote
Old 04-15-2013, 01:14 PM   #5
950slider OP
Oddometer: 118
Bluhduh My oil change OUCH parts
If I e-mail someone an image of my parts, would someone please put 'em up for me.
I seem to have a problem attaching the photo here...
Thanks....
Old 04-15-2013, 01:27 PM   #6
crazybrit
crazybrit's Avatar
Oddometer: 8,555
Thanks....
http://advrider.com/forums/showthread.php?t=919
Signup for a free photobucket account. When you've uploaded the image. Select "get links" and copy the IMG link. Paste that into your post (ctrl-v).
crazybrit is offline   Reply With Quote
Old 04-15-2013, 02:18 PM   #7
Katoom72
Katoom72's Avatar
Oddometer: 912
Just use http://imgur.com/ No signups needed
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 04-15-2013, 02:38 PM   #8
Supahflid
Wheelieless
Oddometer: 3,774
The owner of this site, Baldy, also owns Smugmug. A lot of folks on this site think it's nice way to kick him a few bucks by paying Smugmug for image hosting, although you can use other image hosting sites.
Sorry about your troubles; I probably won't be much help, but I'm hoping the best for you!
Supahflid is offline   Reply With Quote
Old 04-15-2013, 03:17 PM   #9
Motomedic
Motomedic's Avatar
Oddometer: 2,503
How's your shifting? I can't remember for sure, and I'm really grasping at straws here, but I'd wonder about the shift drum bearings if it were me. I thought they were both ball bearings (schematic shows both being balls), but I could be wrong.
None of the other bearings, especially any of the "roller" or "needle" bearings are 4.5mm wide. Crank is supported by plain bearings, the balance shaft (or combination shaft, or whatever the hell KTM calls it) is supported by ball bearings, as are 3 of the 4 trans shaft bearings, outboard countershaft is a roller bearing.
The only other thing I'd wonder about is the bearings the shift shaft runs in, but the schematic calls for a 12mm wide needle bearing.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic screwed with this post 04-15-2013 at 03:22 PM
Motomedic is offline   Reply With Quote
Old 04-15-2013, 03:54 PM   #10
Orangecicle
On a "Quest"
Oddometer: 3,149
Gloom, Dispair . . . .
How I'd feel if that happened to me:
Old 04-15-2013, 07:47 PM   #11
Brokein2
Oddometer: 232
With a twin like we have.....there is usually no harm riding it until you find a piston stuck to the drain plug.
Craig A.
'09 990 ADV
'11 R1200RT
'14 R1200GS
Brokein2 is offline   Reply With Quote
Old 04-15-2013, 08:12 PM   #12
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,152
Just to clarify: you found these in the OIL TANK? or in the ENGINE? drain plug magnet.
I assume the engine drain plug, because there is NO WAY these items can get into the oil tank unless they fell out of an oil bottle when you filled it.
KTM has had some problems with the bearing on the transmission main shaft right behind the clutch on other models. Easy to check. Pull the inspection cover and wiggle the clutch up/down, front/back. If you get more than a few thou... start saving your money.
"Son, you can't do both"
Old 04-15-2013, 08:30 PM   #13
sstewart
sstewart's Avatar
Oddometer: 1,058
Bearings
He should know,had his bike scattered all over my damn shop,just saying.
sstewart is offline   Reply With Quote
Old 04-15-2013, 08:52 PM   #14
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
I have an engine in pieces, the only small rollers I remember in the motor are the gear shaft ones.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 04-15-2013, 09:40 PM   #15
Motomedic
Motomedic's Avatar
Oddometer: 2,503
When this happens (notice the large chunk missing from the one on the right)on a 6 month 25k mile odyssey:
It's followed by this:
Notice the size of the bearing lands on the shift drum, hence my guess that that's the bearing that let go. If it's not the shift drum bearings, I'd go with the shift shaft.
If you look close, you can see one of the shift shaft needle bearings.
As for riding it like that, imagine what could happen if one of those rollers found it's way into the scavenge oil pump, stopping the rotors and shearing the drive pin in there. No oil pressure usually means a quick death for the plain bearings that support the crank. Or how about what would happen if it found it's way into the trans, between gears? It could lock the trans, causing a sever and drastic loss of control as the back wheel locks up at speed.
Park it until you fix it. Sorry, but it looks like you're splitting cases. Look at the bright side though- if I did it in a redneck's (oops-I mean inmate's) garage in Alabama (Hi Scott! ), how hard can it be?
Feike
Motomedic screwed with this post 04-15-2013 at 09:49 PM
Times are GMT -7.   It's 11:16 AM.
