Old 04-16-2013, 02:19 AM   #16
950slider OP
Oddometer: 118
Wink roller bearing OUCH!
Yes... I'm starting to think Trans related bearing. I'll pull things apart on the weekend and check the clutch drum first. I suspect the shifter shaft for the size of the bearing.
As I've only seen 4 bearings thus far...I think I'll use a strong magnet and hope I can move 'em out the drain plug hole. This is wishful thinking that those bearings are in the crankcase pan!
Only small metal fragments were found on the screens, but no large particles or pins.
The hunt will go on!
Thanks for all who have pitched in so far.
Can't 'Slide' without the 950!
Originally Posted by Motomedic View Post
When this happens (notice the large chunk missing from the one on the right)on a 6 month 25k mile odyssey:
It's followed by this:
Notice the size of the bearing lands on the shift drum, hence my guess that that's the bearing that let go. If it's not the shift drum bearings, I'd go with the shift shaft.
If you look close, you can see one of the shift shaft needle bearings.
As for riding it like that, imagine what could happen if one of those rollers found it's way into the scavenge oil pump, stopping the rotors and shearing the drive pin in there. No oil pressure usually means a quick death for the plain bearings that support the crank. Or how about what would happen if it found it's way into the trans, between gears? It could lock the trans, causing a sever and drastic loss of control as the back wheel locks up at speed.
Park it until you fix it. Sorry, but it looks like you're splitting cases. Look at the bright side though- if I did it in a redneck's (oops-I mean inmate's) garage in Alabama (Hi Scott! ), how hard can it be?
950slider is offline   Reply With Quote
Old 04-16-2013, 11:30 AM   #17
Qwik
Adrenaline Addict
Oddometer: 6,549
I dont have a transmission but if there is anything else you need for the motor let me know. I have a motor I am dismantling.
T
Speed bumps never seem to make me go any faster
Qwik is online now   Reply With Quote
Old 04-17-2013, 12:35 AM   #18
950slider OP
Oddometer: 118
Here's a pic
Edit: no, didn't find the dime in there
Old 04-18-2013, 11:25 PM   #19
Zuber
Zoob
Zuber's Avatar
Oddometer: 1,943
Those bearings are tiny. Not from a main bearing in the tranny or engine. They are about the size of the needles for the bearing on the RH end of the shift drum. Too small for the locating pins on the end of the shift drum.
This debris can't get into the oil pumps because of the two screens on the pump intakes.
I'd pull the RH engine cover first.
"Son, you can't do both"
Old 04-20-2013, 10:38 PM   #20
950slider OP
Oddometer: 118
Laugh Thanks for the participation!!!
Looked through the parts diagrams and have come up with Zip/Zero/Nada... so a hint of any lead is encouraging... thanks!
Time to get my hands grubby once again.
Old 04-21-2013, 07:00 PM   #21
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Talking I think I know what it is
the shift drum bearings are ball not roller
I think #23 is what you're dealing with:
it's a two-row needle bearing, and the race is thin as in your photograph. As it's an "04 she's had plenty of miles to wear that thing out, and the clutches are known for being tricky on the LC8's
put her on the sidestand and pull the outer cover off the clutch and start there- no oil will drain out, even if you have to take the RH engine cover off to get futher into the clutch (and to start fishing the rest of the bearing out! )
Don't run her until you figure it out... but I'll bet you that dime in the picture that's your part!
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 04-21-2013, 10:43 PM   #22
wiswoodsguy
Kmart shopper
wiswoodsguy's Avatar
Oddometer: 1,901
My bet is that it's part #23 as well.
I found the same needle bearings in one of my oil changes on my 520. Problem was, I changed fluids on all 3 of my bikes that day. Took a week to find the same schematic for the whereabouts of a needle bearing in a KTM motor, I was told that is the only one in there or at least in my 520. I did ride the bike shortly after that and it seemed fine - only a very short mile or so - and it has been parked ever since. Motor is coming out very soon, it needed a good going thru anyways
Sorry your in the same boat (Bust Out Another Thousand)
wiswoodsguy is offline   Reply With Quote
Old 04-22-2013, 09:22 AM   #23
950slider OP
Oddometer: 118
Wink Yup...Got 'em
You boys just made this bike bum a Happy Camper!!!
A raised glass for looking and sharing your 'insights'
Time to order that bearing (has anyone ever gotten any parts order quickly from KTM?)
Old 04-23-2013, 07:46 AM   #24
Katoom72
Katoom72's Avatar
Oddometer: 831
If i order on monday i get the parts on thursday.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 04-26-2013, 01:34 PM   #25
Masa
Masa's Avatar
Oddometer: 297
Sorry but I don't see any resemble between these two??
Masa is offline   Reply With Quote
Old 04-26-2013, 06:01 PM   #26
950slider OP
Oddometer: 118
Cry You're right...
Clutch hub has no play
Time to throw it down on its side and get dirty
Old 04-27-2013, 06:57 AM   #27
charlie264
charlie264's Avatar
Oddometer: 8,238
Looking through the manual, did a search for needle bearing.
Idler gear on the counter shaft.
Reduction gear off the flywheel, magneto.
Timing gear, (too big to be one in photo)
Clutch, as shown too big to be one in photo.
charlie264 is online now   Reply With Quote
Old 04-28-2013, 03:32 PM   #28
950slider OP
Oddometer: 118
Wicked Thanks Charlie...
I looked thru my parts book that came with my bike the first time around, and believe it or not, there are quite a few roller bearings in the 950 motor.
The problem was mentally sorting out which one 'fits' the look and description of what I had in hand...
Thanks for your reply.
Old 04-28-2013, 06:32 PM   #29
Motomedic
Motomedic's Avatar
Oddometer: 2,468
Here's a unique concept- TAKE THE BLOODY THING APART.
Much easier to determine which bearing has let go when it's disassembled.
Feike
I don't have to agree with you to like you or respect you. -Anthony Bourdain
Motomedic is offline   Reply With Quote
Old 04-29-2013, 02:47 AM   #30
Masa
Masa's Avatar
Oddometer: 297
... I suspect the shifter shaft for the size of the bearing.
That looks like a closest match, if you look at this photo by Steverino:
But then again maybe not.. Needles you pulled out are really short.
Times are GMT -7.   It's 12:12 PM.
