Old 04-15-2013, 07:03 PM   #1
telejojo OP
telejojo's Avatar
Oddometer: 461
Dot3 or 4
I have a 79 KZ1300 and it calls for dot3 brake fluid and I have a supply of 4 from my MG and Triumph days can I use 4 and it be ok?
08Concours,09KLR, 80CBX 79KZ1300 , 2013 Zuma 50 2012 04 V-Strom,1974 KZ900 04 ZRX
telejojo is offline   Reply With Quote
Old 04-15-2013, 09:19 PM   #2
k-moe
Oddometer: 2,642
Yes. DOT 3,4, and 5.1 (NOT 5), are all compatible. DOT 4 has a higher boiling point than 3, otherwise they are the same in terms of performance.
k-moe is offline   Reply With Quote
Old 04-16-2013, 04:53 AM   #3
JerryH
Oddometer: 5,069
I have always used DOT 3. It is a LOT cheaper than DOT 4, and the only difference is the boiling point. Never had a problem. I used DOT 3 in a 1500 Goldwing and it worked fine. If you have a sport bike and do a lot of aggressive riding, then maybe DOT 4 might be the best choice. But you can use it anywhere, except late model Harleys, that use DOT 5, which is not compatible with anything else.
JerryH is offline   Reply With Quote
Times are GMT -7.   It's 09:20 AM.
