Old 04-16-2013, 01:10 AM   #1
MOLAHS OP
Sisyphus
MOLAHS's Avatar
Oddometer: 1,650
19/ 990 Adv wheels
Seeking advice on using an Alpina 19" front tubeless wheel and keeping the 18" rear. Any potential problems, handling and/or otherwise ? Do you need to shorten the sidestand ? Will the centre stand be OK ? The reason for the request on 19/18 info is from a cost POV and the fact in OZ you can import up to $1000 w/o duty wheras two wheels 19/17 would be way over that limit.
The Myth of Sisyphus
MOLAHS screwed with this post 04-16-2013 at 01:27 AM
MOLAHS is offline   Reply With Quote
Old 04-16-2013, 05:09 AM   #2
kingrj
kingrj's Avatar
Oddometer: 431
I can only tell you what switching to the 19/17 did but I had to shorten the side stand by an inch. The center stand still works fine but it is a hell-of-a-lift to get it up on there now..keeping your 18 on the rear should make it easier. Handling on the road will be much improved. That fat 19 on the front will bite much better in hard cornering than the 21..You will lose some trail but I only noticed stability issues when passing large trucks. Enjoy!
kingrj is offline   Reply With Quote
Old 04-17-2013, 04:42 AM   #3
mcmann
Motorcycle Maniac
mcmann's Avatar
Oddometer: 1,897
The 18" rear works fine with a 19" front . . . Try maximum spring tension in the rear to offset lowering the front for the side stand.
Motorcycles are Life
If I am not riding . . . I feel like I am missing out on living . . .
mcmann is online now   Reply With Quote
Old 04-17-2013, 04:58 AM   #4
mousitsas
mousitsas's Avatar
Oddometer: 2,772
you don't need to shorten the sidestand, just put a washer under the ss mounting plate at the lower bolt, in order to change the angle or deployment.
Old 04-17-2013, 05:42 AM   #5
tomdubz
getting there
tomdubz's Avatar
Oddometer: 509
Genius!
This is my signature: TD
tomdubz is online now   Reply With Quote
Old 04-17-2013, 05:27 PM   #6
MOLAHS OP
Sisyphus
MOLAHS's Avatar
Oddometer: 1,650
Thanks for that advice. I gather that there is not a problem with the wider 19" rim alongside the std 18" rear rim ?
Old 04-18-2013, 10:19 PM   #7
mousitsas
mousitsas's Avatar
Oddometer: 2,772
Not a problem, but expect to fiddle a bit with suspension settings to set it where you want.
Times are GMT -7.   It's 03:52 PM.
