Old 04-17-2013, 10:12 AM   #16
alexisan OP
Oddometer: 190
Just went into the garage again...
I started the bike, then took the "+" cable of the battery and measured dc straight from there....14 volts!!!
I was under the impression you always leave the battery in the system while measuring...
Obviously it "sucks away" (sorry bad English) what is provided...
Seems to be good now...
alexisan is offline   Reply With Quote
Old 04-17-2013, 10:13 AM   #17
alexisan OP
Oddometer: 190
@ davesupreme: sorry man, my English is just not good enough sometimes...eventhoug I stayed 3 years in Alabama ;-)
Old 04-17-2013, 02:37 PM   #18
davesupreme
grand poobah
Oddometer: 1,584
it's all good boss....
so you found it, sounds like a bad battery.... if you have 14 VDC at the voltage regulator leads while they're off the battery, then it sounds like you have a bad battery to me..... i just don't like all those connections/plugs between the stator and the battery....mine were all fried and arc-ed.... i just soldered everything hard between the stator and the regulator, and no more problems.... look at 'batterymart' for a a cheap battery.... i just put an electric starter on mine, and i have the smallest one they got, and it works great, and it's like $30 shipped.... lemme find a link....
http://www.batterymart.com/c-ktm-sx-...e-battery.html
i got the small one, and it fires mine great.... you can get the 5 series for almost the same $$$ and more cranking amps....
it's all good....
davesupreme is online now   Reply With Quote
Old 04-25-2013, 09:11 AM   #19
alexisan OP
Oddometer: 190
Guys. The batt still don't seem to be charging. I measured again. 14,2 volts with lights off. 12 volts with lights on...??
Old 04-25-2013, 10:11 AM   #20
davesupreme
grand poobah
Oddometer: 1,584
how old is the battery?.....
Old 04-27-2013, 09:55 AM   #21
alexisan OP
Oddometer: 190
Think the battery is old. Was riding the whole day today..with lights off it seem to charge just enough..
Old 04-27-2013, 10:08 AM   #22
crazybrit
crazybrit's Avatar
Oddometer: 8,556
I know English isn't your first language but it was suggested long ago to try a new battery. You'll help yourself if you can be more methodical and follow the advice that is given.
For testing purposes the battery can be from a different bike (as long as it's known to be working well). Just rest it on top of the cage and connect up the terminals.
crazybrit is offline   Reply With Quote
Old 04-27-2013, 10:52 PM   #23
alexisan OP
Oddometer: 190
will try that. sorry that I am causing a bit of confusion here...
Old 07-14-2013, 08:41 PM   #24
alexisan OP
Oddometer: 190
The Story goes ok. No charge for battery...
Starting with stator:
Multimeter on 2000 ohms
Connect to yellow and white cable. Zero resistance
Is that supposed to be?
Times are GMT -7.   It's 07:30 PM.
