Old 04-18-2013, 05:05 PM   #16
Plaka
Brevis illi vita est
Oddometer: 4,588
Originally Posted by skipn View Post
I will do that. It is an H4. Also, I tested it to make sure it wasn't the problem.
I tested the switch's green leads to the hi/lo, and horn and get power, and if I jumper to the wires to the light on the switch, I get light. It just looks like juice in, but none out from the switch, other than the flash switch.
I will continue tracing on the assumption it is not as simple as juice in/juice out, find the break.
Thanks.
Check your wiring diagram for a so-called "headlight relay". If found, jumper around it on the lights side.
Old 04-18-2013, 07:24 PM   #17
Noswal
Noswal's Avatar
Oddometer: 79
Just throwing this out-
when your checking and testing the headlights operation, make sure that:
(a) you have the key in the second (run) position.
(b) the little yellow headlight switch on the control housing is in the fully down position (first is just the parking light).
Good luck.
Noswal is offline   Reply With Quote
Times are GMT -7.   It's 12:07 AM.
