Old 04-17-2013, 11:59 AM   #16
Kai Ju
Kai Ju's Avatar
Oddometer: 1,836
no Y junction, already suggested that only to be educated.......
Kai Ju is offline   Reply With Quote
Old 04-17-2013, 04:48 PM   #17
batoutoflahonda
Oddometer: 1,383
Item 17. School's out.
Max's BMW + steering
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda screwed with this post 04-17-2013 at 04:55 PM
batoutoflahonda is offline   Reply With Quote
Old 04-17-2013, 05:01 PM   #18
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,232
Huh? School on what, how to post images? :)
Old 04-17-2013, 05:20 PM   #19
patrkbukly OP
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,048
Dumroll please...
You ready.....
G _ d D #*mn Mother F#*"> son of a biscuit.
Went over each component from beginning to end with no results. Pulled the cables off one at a time and laid them against the originals.....
......the cables are about 1.5 cm shorter than the stock ones...each one....so I assume they were mislabeled, mispacked or who knows what but damn that was a lot of dickin around for nada.
S&M Motors on Ebay.
I can't believe it.
And the whole job started because I was trying to correct a stutter or cough when I begin to accelerate. The bike runs great at speeds its just the takeoff has a stutter almost as if the carbs are out of sync. So I am back where I started, original cables, same issue but....I am idling at 950 now.
Thanks for everyones replies, answers, support and just overall usual community feel.
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is offline   Reply With Quote
Old 04-17-2013, 05:48 PM   #20
Kai Ju
Kai Ju's Avatar
Oddometer: 1,836
Shool's back in session.
look at items 12, 18 and 19, which connect to 17, in the same frame, clearly identified as the Choke Cables
Kai Ju screwed with this post 04-17-2013 at 05:58 PM
Old 04-17-2013, 05:57 PM   #21
Kai Ju
Kai Ju's Avatar
Oddometer: 1,836
Originally Posted by Patrick C Buckl View Post
You ready.....
S&M Motors on Ebay.
I can't believe it.
Glad you found the "problem", now onto the real problem. Stumble off idle.
Loosen the hose clamps on the airbox side of the carb, make sure the head side ones are tight. Now try and rotate the carb body around it's axis. If you can, your instake spigots are loose and are likely the source of an airleak. Tighten to reseal. That vintage should have a slot cut on either side of the spigot that you can insert a piece of steel into to tighten them up with.
If that's ok, take a look at your needles and needle jets since the tend to wear on each other, also affecting the metering.
Old 04-17-2013, 07:27 PM   #22
AntonLargiader
Oddometer: 4,232
S&M Motors on Ebay.
Are these actual BMW cables, with the BMW name and part number stamped on them in white ink? Or are they some sort of counterfeits or clones?
Old 04-17-2013, 07:48 PM   #23
patrkbukly OP
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,048
Clones I think.
I have a feeling they were clones. Ebay BMW R100 gs throttle cable left and Right.
S&M Motor Company
19.95 each & free shipping, not worth it at all after this.
Mae West
Old 04-18-2013, 05:09 AM   #24
AntonLargiader
Oddometer: 4,232
Not worth anything if they're simply wrong. Sounds like justification for negative feedback to me.
Old 04-18-2013, 06:38 AM   #25
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,640
And the ironic thing is that BMW throttle cables cost about that from a reliable source. This is one reason to avoid off-brand parts from Fleabay.
S&M, eh? Classic double entendre.
--Bill
'73 R60/5 Toaster
Old 04-18-2013, 07:53 AM   #26
patrkbukly OP
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,048
Agree with Bill
I know, I knew better, I knew better, I knew better and now....I know better.
Mae West
Old 04-18-2013, 07:56 AM   #27
Kai Ju
Kai Ju's Avatar
Oddometer: 1,836
If it's a reputable seller you should be able to return them for a refund. I would hope, anyway.
Old 04-18-2013, 08:04 AM   #28
AntonLargiader
Oddometer: 4,232
Those cables sound very close dimensionally to the 584/585 cables for the '88~90 GS.
Old 04-18-2013, 08:11 AM   #29
Jim Day
full manic mechanic
Jim Day's Avatar
Oddometer: 909
Alrighty everybody,
so I replaced the throttle cables....R100 GSPD, 1993. All was simple smooth and easy. Now when I start her up I idle between 3500 and 4,000.
What the hell am I missing?
That is insane
Jim Day is online now   Reply With Quote
Old 04-18-2013, 08:14 AM   #30
Mugwest
Mugwest's Avatar
Oddometer: 6,239
Send in the clones:
The S&M fleaBay store has a lot of cool shit for old European iron (Whitworth sockets, anyone?), but my sense is that it's a savvy M/c guy that's sourced a cheap probably Asian mfr to do knock-offs for pennies. Then sell at full BMW retail.
Checked MAX on those cables and they're the same price as the clones. Plus, MAX gives you M&Ms, not S&Ms
Mugwest is online now   Reply With Quote
Times are GMT -7.   It's 12:37 PM.
