Old 04-17-2013, 12:11 PM   #1
walkingbear OP
walkingbear's Avatar
Oddometer: 3,543
Info Needed .. front end swap
I know the K100 front end would fit on a R100GS. Will it fit on a R90?
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is online now   Reply With Quote
Old 04-17-2013, 12:48 PM   #2
ericrat
Oddometer: 1,202
My understanding is, essentially, yes. It is a "straightforward" swap. If you check a site like http://www.allballsracing.com you will find the K75/K100 and the Airhead Rs use the same bearing kit.
Steering stops, gauge mounting, turn signals, etc all need attention.
Eric
Have you visited ride reports lately ?. click HERE
ericrat is offline   Reply With Quote
Old 04-17-2013, 01:51 PM   #3
KhaoSanMan
Airhead
KhaoSanMan's Avatar
Oddometer: 590
I have a K100 front end on the shelf and it would be easy to measure if you need any specifics. PM me if needed.
KhaoSanMan is offline   Reply With Quote
Old 04-17-2013, 02:23 PM   #4
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,511
Yes.
David Hunn:
R100GS Ray Peake special.
http://www.advrider.com/forums/showt...uild+australia
gsd4me is offline   Reply With Quote
Old 04-18-2013, 06:42 PM   #5
super-single
super-single's Avatar
Oddometer: 121
Nice Dave......
Real nice !
i've monkeyed with the juice and fiddled with the flow .
super-single is offline   Reply With Quote
Old 04-19-2013, 02:53 AM   #6
chasbmw
Oddometer: 2,253
Originally Posted by gsd4me View Post
That's really nice, it's just fitting the spoked wheel that's the issue?
Charles
1971 Commando Fastback
Old 04-19-2013, 02:57 AM   #7
Plaka
Brevis illi vita est
Oddometer: 4,612
Fitting the blower, the fuel injection and paying for the shocks was the issue. Somebody could have bought a stone stock Ducati for what that thing cost---and the Duck would run the pants off it.
The K uses a bigger axle, so the wheel has to be able to take that---or the axle modified, which sort of misses part of the point of having the K front end---stiffness.
Old 04-19-2013, 03:17 AM   #8
gsd4me
90% bluff
gsd4me's Avatar
Oddometer: 7,511
I'm pretty sure the Ducati would not still be running almost untouched after over 20 years and 275,000 kilometres.
David Hunn:
Old 04-19-2013, 05:54 AM   #9
Plaka
Oddometer: 4,612
170877 miles on a 90S? First over pistons and a bore job at around 120,000mi. Valve job a little sooner. Transmission work and new rear splines a little later, a clutch or two (three on that thing) in there somewhere. But if you took care of the wheel, head and swing arm bearings they're still going strong but you've replaced there discs---and more than a few rear spokes I'll bet. Ya gotta pay to play and beemers will go a million miles and more, but you replace a lot of stuff along the way. granted you might replace more stuff sooner on the Duck, but it's makeing more power.
Times are GMT -7.   It's 06:17 PM.
