Old 04-18-2013, 01:48 PM   #16
Beater
Dirty
Beater's Avatar
Oddometer: 3,203
Originally Posted by Padmei View Post
Best thing about this fault is it creates a good discussion for future successes for others- keep up the good work.
+1 This is exactly the discussion I'd like to have.
Fred
'85 R80RT G/Sified <|> '91 R100GS Bumblebee (103K miles and climbing) <|> '73 R75/5 LWB
Airhead Zen: Ride - Repair - Ride - Maintain - Ride - Repeat
Beater is offline   Reply With Quote
Old 04-18-2013, 06:21 PM   #17
Warin
Retired
Oddometer: 2,080
Originally Posted by Jim Day View Post
Now I got a question for you. At 7000 engine RPM how fast is that shaft turning?
Wrong question
You can pull the clutch and kill the motor and the drive shaft will still be spinning if you are moving down the road.
As the drive shaft is directly connected to the rear wheel through the bevel drive the speed of the drive shaft is directly related to the bikes speed (via the wheel circumference and the bevel drive ratio.
If you went to a larger diameter shaft that slipped over the original shaft (without machining it) then you'd have a slightly stronger effective joint - the stress is related to the radius of the wielded joint. Provided it fits down the swing arm... ?
Warin is offline   Reply With Quote
Old 04-18-2013, 06:39 PM   #18
KustomizingKid
Oddometer: 679
Shoulda tig welded it...
2000 Xr650r!
KustomizingKid is offline   Reply With Quote
Old 04-19-2013, 06:12 AM   #19
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,514
I have not failed, I have merely found 10,000 ways that do not work. Thomas Edison
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is online now   Reply With Quote
Times are GMT -7.   It's 04:30 PM.
