Old 04-18-2013, 03:05 PM   #1
Big Bamboo OP
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,760
Late model airbox "snorkel" removal
I'm talking about the rubber elbows inside the late style airbox on a 1992 GS. Is there a trick to getting them out? I assume the are removed towards the inside of the 'box. I tried a couple test whacks with a 2x4 and a hammer, but they didn't budge. Time for a bigger hammer?
Big Bamboo is offline   Reply With Quote
Old 04-18-2013, 03:11 PM   #2
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,979
You pull the metal sleeves out from the airbox (towards the carbs), the rubber airhorns are held in my that sleeve, and a lip on the their end.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 04-18-2013, 03:30 PM   #3
ME 109
ME 109's Avatar
Oddometer: 2,957
Yeah, pull those sleeves out Tim. They may be held in with a smear of silicone too.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 04-18-2013, 03:43 PM   #4
supershaft
because I can
Oddometer: 9,116
Those are velocity stacks man! I think a stock engine and even a slightly modified setup runs better with them just like they come out of the box. My setup now runs better with the stock stacks shortened to just inside the box but my engine is far from stock now.
Old 04-18-2013, 04:32 PM   #5
Big Bamboo OP
Big Bamboo's Avatar
Oddometer: 3,760
Thanks for the replies! I'm not removing them for the sake of performance. I need to get them out of the way in order to remove the airbox from the bike. The top two bolts are giving me a hard time, and there's no room for anything but an allen wrench in there...
Old 04-18-2013, 06:51 PM   #6
supershaft
because I can
Oddometer: 9,116
Old 04-18-2013, 07:46 PM   #7
ME 109
ME 109's Avatar
Oddometer: 2,957
Velocity stacks are plastic, not rubber.
And they are on the outside of the airbox, not the inside.
Old 04-18-2013, 08:08 PM   #8
Big Bamboo OP
Big Bamboo's Avatar
Oddometer: 3,760
Wouldn't "plenum" be a better term?
Old 04-18-2013, 08:12 PM   #9
supershaft
because I can
Oddometer: 9,116
No. That's something else entirely. Stacks can be made out of whatever. Rubber, plastic, aluminum, steel, brass, what have you. They can be inside of an airbox as well. They are what they are and work like they work in a box or not.
Old 04-18-2013, 08:56 PM   #10
mendoje
Oddometer: 237
Not quite. "Velocity stacks" is a catchy term some hot rodder came up with eons ago. The correct term, whether we're talking aero or fluid dynamics is "bell mouth". And they can be made out of anything, as long as the shape is maintained for the intended purpose. If you have bellmouths feeding your throttle bodies, sticking out of the hood of your race car, you want them made out of something substantial so they dont distort or collapse under air loads when at speed. But inside an airbox, rubber is just fine.
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 04-18-2013, 08:58 PM   #11
ME 109
ME 109's Avatar
Oddometer: 2,957
Doh! You're right.
Tim wasn't asking about his velocity stacks tho'
Did you get the "rubber elbows" out Tim?
Oops! well of course the elbows are part of the stack as well, but let's not get sidetracked by technicalities!
Old 04-18-2013, 09:54 PM   #12
Plaka
Brevis illi vita est
Oddometer: 4,609
So use an allen wrench?
Old 04-21-2013, 08:30 AM   #13
dfc
Reluctant Cannonball
dfc's Avatar
Oddometer: 2,767
Those are a bear to get out, I feel yer pain. what you will find is that the fix for this is to swap the hex head bolts on the starter with the socket head bolts (allen) in the airbox when you reassemble, makes both items easier in the future. Why BMW didn't do this in the first place is a mystery to all
'twas ever thus
dfc is offline   Reply With Quote
Old 04-21-2013, 10:55 AM   #14
Plaka
Oddometer: 4,609
I looked at mine because I have to take it out shortly. I put slotted heads in there (and then forgot). Same as a allen head...hold the inside and take off the nut on the other side.
Old 04-21-2013, 11:55 AM   #15
supershaft
because I can
Oddometer: 9,116
I don't understand how they are a bear to get out? That whole setup is a breeze IMO.
Times are GMT -7.   It's 07:02 AM.
