Old 04-20-2013, 07:38 AM   #1
walkingbear OP
walkingbear's Avatar
Oddometer: 3,537
83 R100 Spark plugs
What would be the best spark plugs for South west.. AZ
Cooler plug?
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 04-20-2013, 01:19 PM   #2
Plaka
Brevis illi vita est
Oddometer: 4,612
Cooler plug?
Stock plugs. Evaluate the proper heat range, as well as the mixture, by doing plug chops (google--->)
Doesn't matter where you are, the temperature in that cylinder is very close to the same. Gas and air burn at X temperature and X is a constant. The whole motor might run a lot hotter in a hot climate, less temp,. differential to the air to provide cooling.
A hotter plug literally runs hotter (center electrode). it might be desirable to burn off oil fouling in a very worn engine. I've used a hotter plug in the left lower plug of a dual plug setup because of gas and oil fouling. A cooler plug literally runs cooler and might be desirable when running bad gas and having pre-ignition problems.
You might also go hotter or cooler with various engine modifications.
The temperature of the plug is determined by the construction. The hotter plug has a longer center electrode (going back into the plug body) making a longer path for heat to get to the head and be dissipated. The colder plug has the reverse and it's center electrode cools more and more quickly.
Times are GMT -7.   It's 10:32 AM.
