Old 04-20-2013, 08:04 AM   #1
scapegoat OP
Pushin forward back
scapegoat's Avatar
Oddometer: 2,886
Touring tire longevity
So how worn is worn? I cant understand how some of you get 10K or more from a rear tire. Do you run it until the threads are close to showing,is there still a small amount of tread in the middle? I put just over 3500 miles on new Metz Me88's on a 01 E Glide and the rear is squared off from freeway runnin and bald on the contact patch. The tire was rebranded by Metz over the O/E sidewall spec with the max pressure or 50psi IIRC so thats what I run. I thought is was bad doin a Pirelli N/D every oil change on the Dyna but 3500 miles can be for real. Shinko's, Michelins? any advice? The Dunlops were better but not by much.
Reality is merely an illusion, albeit a very persistent one.
scapegoat is offline   Reply With Quote
Old 04-20-2013, 08:19 AM   #2
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 14,954
Have you seen the new ME880 Ultra?
http://www.americanmototire.com/cata...th=33_165_1067
I've gotten 12,000 on a rear ME880 on a Buell. I have 8700 on the stock rear tire on my Goldwing, I'm keeping an eye on it at this point, I hate tires that don't have tread down the center when new, hard to judge when it's done.
larryboy is online now   Reply With Quote
Old 04-20-2013, 08:23 AM   #3
scapegoat OP
Pushin forward back
scapegoat's Avatar
Oddometer: 2,886
Hum..I have now, thank You for that one. The front is about 70%, I don't care to mix brands so looks like this will likely be the next tire.
Old 04-20-2013, 08:24 AM   #4
Scrivens
Scrivens's Avatar
Oddometer: 565
Road surface and heat make a big difference. I rarely get more than 5000km out of a rear as the surface here is nearly all chip rather than smooth tarmac, and for four months of the year the road surface is baking. On the east coast on smoother, cooler roads I used to get about 12,000km from the same tyres. The pressure on the sidewall is the maximum loaded pressure; you should be running somewhat less than that if you aren't near the listed load rating. Running too high a pressure will also wear tyres out fast, as well as losing grip. Go by the bike's manual and check them if you get a tyre put on. I had a Dunlop K70 set put on one of my bikes recently and the fitter pumped them both to 42psi. Not a good idea for tubed tyres that should be 28F/30R.
(Oh, and on the Sportster, the last Dunlop 401s had 14,000km on them when I changed them out about 6 months back as they were losing grip, despite still having quite a bit of tread. They didn't wear out much but they didn't hold the road very well either. The Avon Venom-X set have done 8,000km and the front is almost gone and the rear has perhaps 1000km left. Longest lasting "grippy" tyres I've had for ages. Note kilometres, not miles, btw.)
Scrivens screwed with this post 04-20-2013 at 08:34 AM
Scrivens is offline   Reply With Quote
Old 04-20-2013, 10:32 AM   #5
jdiaz
Oddometer: 32,259
There was a period in the early 2000s when Dunlop made a 401 in BMW sizes and called it the 401 S/T. Still the best tire we've ever used on a K75 or K100......my wife and I have about 350,000 miles on K75's alone. I think Sue got 23k miles out of a set one year, and they weren't completely bald at the end....just handled weird. Stunningly good in the rain, laughed at chip seal and a full load of saddlebags, and handled just great.
Dunlop discontinued them fairly quickly, because they would sell one set and not see the customer again for five years or so.
jdiaz is offline   Reply With Quote
Old 04-20-2013, 03:00 PM   #6
rockmurf
IBA #31100
Oddometer: 325
Heat and heat cycles and how and where you ride, weight of the bike/load etc all have a bearing on how much mileage you get out of a tire. Always check the sidewall of the tire for tire pressure. If your pressure is too low your tire will run too hot. If you do lots of short rides your tire will have too many heat cycles(when the tire warms up and cools off, warms up/cools off) and what happens is your tire become hard which will effect the wear, ride and handling. If you are a load and or always carry a load your tires will wear out faster. I got 20k miles on a set of goldwing tires and always get more than 10k miles on my fjr and I go 240lbs. I am fanatical about air pressure in the tire. good luck.
rockmurf is offline   Reply With Quote
Old 04-20-2013, 03:41 PM   #7
scapegoat OP
Pushin forward back
scapegoat's Avatar
Oddometer: 2,886
90% of the mileage is in 65+-5 degree weather, solo unloaded headed to and fro work which is 20 miles each way. Id far rather ride the cage it and there once was a cost savings factor but now....geez...time to saddle up the Donk I recon.
Old 04-20-2013, 03:46 PM   #8
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,318
Do you really, I mean, REALLY like the throttle? Do you use a lot of rear brake? Do you ride a lot of rough roads? There are a million reasons you aren't getting much mileage out of your rear tire. I routinely get 8-9K miles from PR2s on the rear of my VFR, and I don't exactly pussy foot the thing around either -- but I hardly use any rear brake, except for crawling around in parking lots.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 04-20-2013, 03:58 PM   #9
Sport
Oddometer: 350
The max pressure listed on the sidewall is NOT what the recommended running psi should be. 'That' can be adjusted to your riding style and weight on the bike (like in touring or two up) so if you're running that rear at 50 psi (that's) why the middle wore thru. Anywhere between 30 and 42 should be your pressure...depending. Remember you typically gain 2-4 psi as the tire heats up. Starting at 50 means that after a short time, you're actually running 52-54 psi and that's just too much. The tire squeezes up, making the center strip quite prominent in tread wear.
Sport is offline   Reply With Quote
Old 04-20-2013, 04:17 PM   #10
joexr
Oddometer: 3,773
Not to mention it's dangerous due to reduced traction from a smaller contact patch.
Old 04-20-2013, 04:54 PM   #11
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 2,073
I get about 10k out of the pilot road 1 on the rear of an SV1000N. That's down to the wear bar not even close to showing cords. I hear Pilot Road 2's do even better with the dual compound.
I don't go crazy with the throttle but I'm not a grandma either.
However I did only get 3500 miles out of a MT75 rear on a Ninja 250, so it's all relative.
Jimmy the Heater is offline   Reply With Quote
Old 04-20-2013, 05:00 PM   #12
joexr
Oddometer: 3,773
The Pilot Road 2 is the same compound in the center. The sides are softer.
Old 04-20-2013, 07:50 PM   #13
PhilB
PhilB's Avatar
Oddometer: 1,331
The sidewall pressure is the maximum rating, not at all the recommended pressure. So that's part of your problem. Your owners manual will have the recommended ratings for your bike, which usually are somewhere more like the low- to mid-30's. As others have said, it depends a LOT on what you ride, and how you ride, and the conditions where you ride, and so on. Heavy bikes or heavy loads on bikes will wear faster. More powerful bikes will wear faster.
I run Metzelers, with a sport-touring on the rear and a sport tire on the front. My Monster is light, not extremely powerful, and I am not a hard rider. I typically get about 10K to 12K out of a rear, and 15K to 20K out of a front, and I do run them pretty much to the end. Not down to the cords, but yes down to the wear markers.
PhilB
1993 Ducati M900 Monster "Patina" (236,000 miles, so far) -- 1995 Ducati M900 (wife's bike) -- 1972 Honda CB450 (daughter's bike) -- 1979 Vespa P200 (daughter's scoot) -- 1967 Alfa Romeo GT Jr. (1300cc) -- 1964 Vespa GS160 (160cc 2-stroke) -- 1962 Maicoletta scooter (275cc 2-stroke) -- 1960 Heinkel Tourist 103A1 scooter "Elroy" (175cc 4-stroke)
PhilB is offline   Reply With Quote
Old 04-20-2013, 08:50 PM   #14
Cakeeater
Oddometer: 951
I got more than 20,000 out of a late model Harley touring tire. The tires are substantially wider than yours. And as others have said, a key to long rear tire life is back brake use. I rarely use my back brake, except on dirt or doing really tight turns...or when I'm trying to hustle the big beast at a good clip in twisties. but in stop and go driving, almost never.
I'm no engineer and I have nothing to base this on other than my own experience, but it seems rear braking on any two-wheeler (bicycles, motorbikes) really wears out the rubber more than similar braking does on a front tire. I know a front tire has much more braking power...so perhaps it's the back tire that is operating closer to it's maximum "grab"...and thus wearing faster??
I brake hard on my front, and I seem to hardly notice any wear. My front stock Dunlop is going to go easily 25,000, maybe 30,000.
Cakeeater
Cakeeater
Cakeeater is offline   Reply With Quote
Old 04-20-2013, 09:01 PM   #15
mike
mike's Avatar
Oddometer: 3,281
5K out of a Shinko 009 rear. It's got cord showing by then. No burnouts, but am kind of heavy handed with the throttle.
009 -
Worst was 2800 out of a Dunlop 220. no burnouts on it either.
2003 ZRX 1200R
mike is offline   Reply With Quote
Times are GMT -7.   It's 09:26 AM.
