Old 11-13-2010, 12:22 AM   #1
hrach1 OP
hrach1's Avatar
Oddometer: 192
Does anybody know where the F800GS fuse box is located?
Does anybody know where the F800GS fuse box is located? I can't find it.
Any help would be appreciated?
hrach1 is offline   Reply With Quote
Old 11-13-2010, 01:06 AM   #2
itsatdm
itsatdm's Avatar
Oddometer: 4,970
Doesn't have one.
Old 11-13-2010, 07:24 AM   #3
hrach1 OP
hrach1's Avatar
Oddometer: 192
I see. I have heard newer bikes are using CanBUs but I didn't know what that is!
Anyway, the reason I was looking for the fuse box was that my iPhone charger is not working anymore. I am using the power outlet next to the ignition switch and it stopped working after the rain so I though I may have burned a fuse or something.
Thats all!
Thanks for your help
Old 11-13-2010, 11:27 AM   #4
itsatdm
itsatdm's Avatar
Oddometer: 4,970
That switch has an amp limit. I think it is 5 amps, then is quits. Should reset though.
Old 11-13-2010, 01:15 PM   #5
Tor
Native Viking
Tor's Avatar
Oddometer: 805
Not 100% sure, but I think you have to cycle the ignition to reset.
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 11-13-2010, 05:40 PM   #6
Pete O Static
Adventure Seeker
Pete O Static's Avatar
Oddometer: 617
Yup.....cycling the ignition to off then on will reset the Canbus.
"The trouble with quotes on the Internet is that you don't really know if they are accurate" - Thomas Edison-
Pete O Static is offline   Reply With Quote
Old 11-15-2010, 09:38 AM   #7
frtzl
Mors longa, vita brevis
frtzl's Avatar
Oddometer: 231
If your power outlet was replaced at the shop with a PowerLet, which is a very common thing, there is a fuse located in-line between the jack and the battery. Easy to find once you take the center section of the faux tank off (6 torx screws).
If the outlet is the OEM CANBUS unit, then it may be that a wire has shorted or come disconnected or the interior of the socket has corroded (which is unlikely) or become grungy enough to prevent a connection.
Good luck,
Fritz
"A word of advice; if anyone uses the phrase 'as the crow flies' in your presence, slap him immediately. You are bound to want to slap him some time later." Metaljockey
My rides:
2009 BMW F650GS (The Cruise Basselope)
2009 Yamaha Zuma 125 (Sold due to new commute)
2000 BMW R1100R (Blaue Engel) (Traded)
2006 DL650 Euro Black, lightly customized (Godzuki) (Sold)
frtzl is offline   Reply With Quote
Old 11-24-2010, 01:39 PM   #8
hrach1 OP
hrach1's Avatar
Oddometer: 192
Thanks guys. The culprit was my iphone Powelet cable. Thanks again
Old 04-30-2013, 10:32 AM   #9
rideiteverywhere
Oddometer: 4
F800GS headlight help
Saw threads. Yesterday, low beam out & warning light on. Today, removed headlight, looks fine. No 12v at the connector with ignition on. If CanBus is supposed to reset, any ideas how to track down the voltage short, loss, etc?
Many thanks.
rideiteverywhere is offline   Reply With Quote
Old 04-30-2013, 10:53 AM   #10
bmwroadsterca
RadioFlyer
Oddometer: 166
Have to start it
Just turning the ignition to ON only lights the small parking bulb. You have to start the engine before the headlight comes on. As such I would not expect to see 12V at the connector if all you did was turn the ignition on.
bmwroadsterca is offline   Reply With Quote
Old 04-30-2013, 11:03 AM   #11
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
Expensive bike and no manual?
Seems common.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 04-30-2013, 12:13 PM   #12
rideiteverywhere
Oddometer: 4
Headlight
Thanks bmwroadsterca. I figured that out right after I posted the thing. No problem w/ 12v at plug, so although the bulb and filament look good under 10x magnification, must be the bulb, eh? So another question might be, not having shopped for the bulb, yet, and light-on being required in California, do you carry an extra?
Old 04-30-2013, 04:49 PM   #13
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
Bulbs go out often on these bikes for some reason. Take your high beam bulb out and put it in the low so you can go shopping legally. Same bulb, no problem.
A couple of basic questions here and nobody toyed with your heads? Opportunity lost. Canbus fuses are invisible, you need the Dealer's special flashlight.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 04-30-2013, 07:15 PM   #14
Hamish71
Hamish71's Avatar
Oddometer: 414
Its under the seat, next to the left handed screw driver....
Now: 13 F800GS, Kalamata Olive, with all the fruit!
Previous: 08 F800GS, 09 KTM 300EXC, 05 KTM 450EXC
Hamish71 is offline   Reply With Quote
Times are GMT -7.   It's 02:04 AM.
