Old 04-21-2013, 05:51 PM   #1
KSUperDuty OP
GNerdly Adventurer
KSUperDuty's Avatar
Oddometer: 24
Help! Stuck in Ft Collins 2 Hours from Home
The front end on my 1000 mile old F800 just developed a shimmy in the front end. I noticed a slight intermittent vibration in the front today, but I chalked it up to uneven pavement. 60 or so miles later I took both hands off the bars at about 40 mph and the bar started oscillating like crazy. Hands on bars it seems fine with only that slight vibration. I'm not experienced enough to know if I should venture home or what I should do. Off the ground, the wheel spins fine, no excessive mud, can't see where the tread is separated or bad anywhere, bead looks fine. I took a couple pictures of both sides of the hub. Am I missing a bolt? What can I check, or what can I do? I have to work in the AM, and I don't really want to overnight here. Waiting patiently in a parking lot.
Untitled by KSUperDuty, on Flickr
KSUperDuty is offline   Reply With Quote
Old 04-21-2013, 06:10 PM   #2
beeper
Badger tickler
beeper's Avatar
Oddometer: 781
Steering stem bearings loose? With front wheel off the ground check steering stem for play. Also could have tossed a wheel weight. Loose spokes?
If nothing obviously missing or loose I'd continue home.
'12 F800GS
'00 Bandit 1200
'74 Honda CL360
beeper is offline   Reply With Quote
Old 04-21-2013, 06:21 PM   #3
waxrash
waxrash's Avatar
Oddometer: 25
Tire pressure?
- Lynn
2008 BMW R1200RT
2002 BMW R1150RT
2008 Kawasaki Versys
waxrash is offline   Reply With Quote
Old 04-21-2013, 06:34 PM   #4
KSUperDuty OP
GNerdly Adventurer
KSUperDuty's Avatar
Oddometer: 24
Thanks guys. Tire pressure is OK, can't find any loose spokes, two wheel weights in place no play between the wheel and the handlebars. I couldn't remember if there was a bolt through the center on each side or not.
Old 04-21-2013, 08:36 PM   #5
sorebutt
Oddometer: 1,835
Check to make sure the forks are tight in the triple clamps and there is the same amount of tube above the top clamp.
Also if you have tools, loosen the pinch bolts on one side of the axle and then bounce the front wheel up and down. Then tighten the pinch bolts again.
sorebutt is offline   Reply With Quote
Old 04-21-2013, 09:39 PM   #6
CheckerdD
CheckerdD's Avatar
Oddometer: 1,286
Just curious. Is the tread on the front tire cupping? Could the tire be out of round. By now you have most likely eliminated mechanical faults. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 04-21-2013, 10:33 PM   #7
KSUperDuty OP
GNerdly Adventurer
KSUperDuty's Avatar
Oddometer: 24
Thanks for the replies. I checked everything I could think of up front, and everything is tight. Visually nothing is different on one side or the other. No cupping on the tire either. I did have a substantial load on the bike, so I took everything off and went for a short spin on some smooth asphalt. The vibration and the handle bar wobble weren't as pronounced with less weight on the bike, but it was definitely still there.
In the end, I decided not to ride the bike back home in the dark. I couldn't get the thought of some kind of high speed wobble debacle out of my head. Its great to be back on a bike, but my 10 year motorcycle ownership hiatus was the result of a burst fracture of my L1 vertebra. I guess I'm still on the cautious side. I rode it to a nearby BMW dealership, and I'll let them fix it on the warranty.
Because of this, I did learn that I need to start packing a better set of tools around. I'm sure there's a post on suggested tools to carry....
Old 04-21-2013, 10:38 PM   #8
_cy_
Oddometer: 6,272
bummer .. failure on a brand new bike
Old 04-22-2013, 02:46 AM   #9
JRWooden
Oddometer: 4,257
How much preload did you have dialed in to rear shock?
JRWooden screwed with this post 04-22-2013 at 02:51 AM
Old 04-22-2013, 03:07 AM   #10
basketcase
lifelong reject fixer
basketcase's Avatar
Oddometer: 1,433
A "tankslapper" oscillation of the handlebars is usually a loose steering head bearing issue.
On a bike that new I expect you are good to ride home without fear. But some bikes just don't take to hands off riding, so I wouldn't tempt fate by trying it every five miles.
'00 BMW R1100RT, Gone away: 5 previous BMW's, 3 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." - Marcus Aurelius
basketcase is online now   Reply With Quote
Old 04-22-2013, 06:10 AM   #11
Tor
Native Viking
Tor's Avatar
Oddometer: 803
What kind of tires do you have up front?
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 04-22-2013, 06:51 AM   #12
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,712
I read scorpion trail
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road – One month to find the rising sun
Loutre is offline   Reply With Quote
Old 04-22-2013, 01:49 PM   #13
_cy_
Oddometer: 6,272
update ... what caused your problems?
Old 04-22-2013, 06:17 PM   #14
KSUperDuty OP
GNerdly Adventurer
KSUperDuty's Avatar
Oddometer: 24
They must actually ride at the dealership where I dropped it off. They are closed on Mondays, so I won't know anything until tomorrow. I should have ridden it home....
Old 04-25-2013, 08:43 AM   #15
KSUperDuty OP
GNerdly Adventurer
KSUperDuty's Avatar
Oddometer: 24
Dealership called. They confirmed the bar shake. They also said they tightened up the steering bearings which minimized the shake, but it did not eliminate it entirely. Apparently they rode their demo F800 and it has a similar shake at 50 mph. The service advisor said that it is just a characterization of the bike because of the rake angle. OK? Sound like a reasonable explanation?
Times are GMT -7.   It's 04:34 AM.
