Old 04-22-2013, 04:55 AM   #1
ridemorestressless OP
ridemorestressless's Avatar
Oddometer: 65
getting connectors out of the ecu plug
Has anyone had luck getting the female connectors out of the ecu plug without damaging them so it can be used again? Do I need a certain tool to get them out?
ridemorestressless is offline   Reply With Quote
Old 04-22-2013, 06:22 AM   #2
Oddometer: 65
Please disregard. Pulling hard and steady worked really well.
Old 04-22-2013, 06:41 AM   #3
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
use a very fine dental pick or large sewing needle to push on & release the small bent tabs that hold it the connector in the plastic housing
you'll need to bend those tabs back out when you reinstall them, otherwise when you push the plugs back together there is a good chance you won't get full penetration (heh heh) & lasting connections between the connectors, in some cases the connector(s) will just get pushed back enough so it looks fine but isn't making a connection- or will come loose down the road.
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Times are GMT -7.   It's 02:15 AM.
