Old 04-22-2013, 06:02 AM   #1
GrenDesb OP
Oddometer: 329
FI light flashing, ABS fault, crazy RPM gauge, unsteady flasher
First ride yesterday.
After a while:
the ABS disengaged itself
GPS would die
the FI light would light now and then
the RPM gauge would jump few thousands now and then
bike would hesitate now and then
flashers would flash unsteadily
Shut off the ignition and restart, the bike is fine for couple minutes but problem comes back.
Everything seems fine when I'm over 5000RPM.
Pluged it on Tune Ecu thinking there could be a stored code but there wasn't.
From searching on here, I suspect something around the charging system, regulator or switch but cant find those exacts symptoms.
Didn't have time to tear into it yet, any cue would help.
GrenDesb is offline   Reply With Quote
Old 04-22-2013, 04:03 PM   #2
GrenDesb OP
Oddometer: 329
Found it
A wire from the ignition switch was cut right where the loom squeeze between the frame and the plastic piece.
The loom didn't have enough slack so when I was turning hard right, the wires would bend quite sharply.
Fixed the wire and made sure there is enough slack for hard left and hard right without the wires taking a beating.
Times are GMT -7.   It's 01:51 AM.
