Old 04-22-2013, 06:24 AM   #1
sstewart OP
sstewart's Avatar
Oddometer: 1,058
Throttle Tube
Which cam should I use? Should I buy the one with the choice of cams?
sstewart is offline   Reply With Quote
Old 04-22-2013, 06:55 AM   #2
hattah79
hattah79's Avatar
Oddometer: 983
Get the works
I got the tube with 3 cams
Found the middle size one was best for me
My 2c
hattah79 is offline   Reply With Quote
Old 04-22-2013, 07:07 AM   #3
henryroten
Oddometer: 261
I got the tube with 'choices' and ended up using the stock cam. The rest tamed it down so much it lost all of it's fun. I guess it depends on what you are trying to achieve.
henryroten is offline   Reply With Quote
Old 04-22-2013, 07:29 AM   #4
Hipster
Hipster's Avatar
Oddometer: 1,815
If you have one of the early 990's with a sensitive throttle, buy the G2 kit that includes both the 300 & 400 cams.
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 04-22-2013, 08:34 PM   #5
sstewart OP
sstewart's Avatar
Oddometer: 1,058
Cams
I have a new 990 Baja. Which should I buy?
Old 04-22-2013, 09:28 PM   #6
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,180
G2 Throttle Tamer, the slow turn initially, then catches up by full throttle.
http://www.cyclebuy.com/shopping/g2/g2_ergo_tamer.htm
"Son, you can't do both"
Old 04-24-2013, 09:58 AM   #7
turdfergeson
Oddometer: 41
Check the link below. I did this last night on my 990 Baja and tested at slow(er) speeds and there is an obvious improvement.
http://www.advrider.com/forums/showp...9&postcount=10
turdfergeson is offline   Reply With Quote
Times are GMT -7.   It's 05:21 AM.
