Old 04-22-2013, 06:54 AM   #1
29andSingle OP
Oddometer: 410
TTR 125 Carb Question
Took the carb bowl off to clean out the pilot jet. The plate/baffle (#38 in pic) in the attached pic has me scratching my head. The diagram essentially shows that it is attached between the main jet and the needle jet. Pictures seem to indicate that the main jet holds it in place.
However the plate/baffle slides easily over the main jet and needle jet since they are the same outside diameter. Nothing appears to hold it in place. When I removed the bowl it just fell out of the bottom. How is this thing supposed to attach?
29andSingle is offline   Reply With Quote
Old 04-22-2013, 02:11 PM   #2
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 1,068
It should just slide over the main jet like you stated your's does with just a little resistance. On my DRZ125 (very similar carb... most parts interchange) and my buddies TTR125, they are both pretty sloppy and we ended up just leaving it off of his carb with no ill effects.
The Letter J is offline   Reply With Quote
Old 04-22-2013, 02:31 PM   #3
29andSingle OP
Oddometer: 410
Yeah I can't imagine this thing staying in place at all. Maybe I'll just leave it off and see how it goes. Any idea what it's purpose is?
Old 04-22-2013, 03:14 PM   #4
joexr
Oddometer: 3,773
It's a slosh baffle to help keep the mainjet from sucking air on rough terrain and jumping.
Old 04-22-2013, 03:54 PM   #5
29andSingle OP
Oddometer: 410
Well that sounds important. I really don't see how it can be worn out but it simply slides on and off with no resistance. That can't be normal or the act of loading the bike on a trailer would knock it loose.
Old 04-22-2013, 04:14 PM   #6
joexr
Oddometer: 3,773
Are you sure the float-bowl doesn't hold it up?
Old 04-22-2013, 04:21 PM   #7
29andSingle OP
Oddometer: 410
I thought the same but the bowl would come into contact with the main jet long before it hit the baffle.
Old 04-24-2013, 06:58 AM   #8
29andSingle OP
Oddometer: 410
Any other thoughts before I put it all back together?
Old 04-29-2013, 04:56 PM   #9
lbbmwtech
lbbmwtech's Avatar
Oddometer: 72
I have a ttr 125 and that is just how they are, the bowl holds it in place.
There is no such thing as an extra nut or bolt.
lbbmwtech is offline   Reply With Quote
Times are GMT -7.   It's 08:27 AM.
