Old 04-22-2013, 01:34 PM   #1
dieselcruiserhead OP
Oddometer: 1,416
Garmin 78 - still a good candidate for an off road GPS?
hi guys,
Been 6 months since I got to the bottom of this and just checking that not much has changed? At the time I came to the conclusion I shoud get the 78 because it does what my old GPS does (older Trex HXC) but can be plugged in and display several tracks at once.
I'm currently on an old eTrex and it does almost everything I want for most off-road riding. My only complaints are wear to the jack when plugged in when riding, so I use batteries, and that you can only load one track at a time instead of several. I'm not interested in the Montana mostly because the price.
this still hold true?
thanks
andreshoumatoff.smugmug.com
Grand Staircase Escalante Road Reports
Cycles South Vintage Moto Trek Movie - check out all 7 parts
dieselcruiserhead is offline   Reply With Quote
Old 04-22-2013, 01:54 PM   #2
250senuf
250senuf's Avatar
Oddometer: 2,329
I'd say YES. Some people don't like the buttons above the screen other than that ...
I still prefer buttons to touch screen. For $200 it's a great value. It has a nice niche between the old and the latest/"greatest" Garmin has to offer.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 04-23-2013, 08:13 PM   #3
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,591
Originally Posted by dieselcruiserhead View Post
hi guys,
thanks
The 78 series is really good value for the money. The 78 and the Montana are the only ones I recommend for bike use since they both have good power options. Anything that uses Mini USB only for power is not worth getting for bike use. Batteries are ok for handheld use but they die quickly if the backlight needs to be on.
Old 04-23-2013, 08:52 PM   #4
Oddometer: 1,416
Awesome - thank you!
Sent from my iPhone using Tapatalk, hence the typos...
Old 04-24-2013, 12:09 PM   #5
mcnut
Oddometer: 1,365
+1, and don't let the fact the 78 is a "marine" GPS or that the buttons are on top worry you, the 78 is almost identical to the 62 function wise and some actually prefer the buttons on top.
Bruce
mcnut is offline   Reply With Quote
Old 04-25-2013, 02:24 AM   #6
dlh62c
Oddometer: 1,603
It's all a compromise.
The GPSMAP 78 uses a patch antenna, which has very good reception as long as the unit is held flat. The 62 uses a quad helix antenna. The quad helix antenna improves reception and is better suited to holding the GPS in a more upright vertical position.
daryl
dlh62c screwed with this post 04-25-2013 at 02:36 AM
Old 04-25-2013, 04:21 AM   #7
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,591
This is true but I've never heard of this causing any real issue in normal use, on a bike, though. My wife had a 76 for years and it was always as accurate as my 60CSx.
Old 04-25-2013, 04:29 AM   #8
dlh62c
Oddometer: 1,603
The point is that the 78 series is different than the 62 in another way other than just button location and the power cable. I've never had any problems with my 62 when held flat.
daryl
dlh62c screwed with this post 04-25-2013 at 04:35 AM
Old 04-25-2013, 04:35 AM   #9
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,591
That's as may be, but the thread is called "Garmin 78 - still a good candidate for an off road GPS?" so it's worth mentioning that the antenna type is a moot point in real use.
Old 04-25-2013, 06:22 AM   #10
Ditch
Ditch's Avatar
Oddometer: 1,099
I've been very happy with mine and with the long battery life I don't bother with the power cable. I usually only do day rides so multi day rides the power cable option might be better.
Like some others, I prefer buttons.
Wendell
You will never find a more wretched hive of scum and villainy....we must be cautious.
Ditch is offline   Reply With Quote
Old 04-25-2013, 09:07 AM   #11
mattmus4357
Oddometer: 667
I'm still loving mine. I've ridden over 1000 miles with it the past two weeks. It doesn't have to be held "flat", I've got mine mounted on the bars at an angle >45 degrees and I've never had a problem.
mattmus4357 is offline   Reply With Quote
Old 04-25-2013, 09:36 AM   #12
Oddometer: 1,416
I missed the crazy deals over the winter, seems like they are about $230 is the best I can find unless someone has a link...
Old 04-25-2013, 01:30 PM   #13
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,410
A little cheaper here:
http://www.ebay.com/itm/NEW-GARMIN-G...item51a7ade2ae
Old 04-25-2013, 01:43 PM   #14
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,591
Originally Posted by Albie View Post
You'd want to make sure Garmin will honour the warranty before buying one of those. I'm not saying they won't, but they do have this policy in effect for eBay purchases.
Old 04-26-2013, 10:51 AM   #15
NorthernTraveler
Long time Adventurer
NorthernTraveler's Avatar
Oddometer: 448
West Marine $200
West Marine has been having the base 78 on sale for $200 off and on every few weeks over the past few months.
If they are not on sale now, they probably will be soon.
NorthernTraveler is offline   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 06:56 AM.
