Old 04-22-2013, 03:02 PM   #1
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 396
990 ADV flat spot
Hi all.. I have an 07 990 Adv. All stock with the exception of a Uni pre filter and 17/45 sprockets. I have had this issue since I have owned it. from 3K to current 20K miles and before the Uni and gearing change.
In 4th gear at about 4K RPM if I'm holding the throttle steady and then roll it on slowly it has a hesitation. Not really a bog but just doesn't go all that smoothly. A flat spot is what I call it for lack of a better description. It is only annoying if I'm going into a turn and it does it then the bike will want to tip over into the turn. It goes away pretty fast if I just keep on the throttle and runs perfect other than that.
Any thoughts on what could be up?
Thanks...
skidxr is offline   Reply With Quote
Old 04-22-2013, 04:13 PM   #2
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 935
Common 06/08 990 stuff. Tuneecu can help you. (but you've got alot of reading to do.)
690R
Old 04-23-2013, 03:04 AM   #3
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,146
Have seen them in the 16s lean there. And 11s at 2500. Mapping is what you need!
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Times are GMT -7.   It's 03:15 PM.
