Old 05-03-2013, 12:25 AM   #166
Cycles East OP
Oddometer: 128
Every woman's dream,, 11 inches,,,, of ground clearance.
Cycles East is offline   Reply With Quote
Old 05-03-2013, 12:29 AM   #167
Cycles East OP
Oddometer: 128
KC sitting on to like a king.
Old 05-03-2013, 12:57 AM   #168
oldxr
oldxr's Avatar
Oddometer: 1,137
In on this 1.I have a soft spot for ct90-110s.I put 10,000 miles on 1 in high school.Used it for a newspaper route then to school and back.I dont know how many miles that bike spent at WOT .If you guys have a ct110 engine with high/lo subtrans that is extra send me a pm.I have a 1985 trx125 crank shaft to build a stroker engine.I have a 1969 sl90 to put this in .The sl90 currently has 104cc displacement .Back in the day I used the sub trans alot-The low range was handy on single track.Best of luck on your trip.
oldxr is offline   Reply With Quote
Old 05-03-2013, 07:02 AM   #169
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,904
Damn guys looks like you have a LOT of work to do! Lookin' good on the fab!
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 05-03-2013, 07:23 AM   #170
R-W
R-W's Avatar
Oddometer: 278
Yes you can!
Not only riding the TAT in the reverse direction but also building the bikes you are gonna ride it with?
Sure beats spending 20k for a shiny German machine and no doubt makes for 100 times more fun and one heck of an adventure.
Damn boys... good deal! I applaud you...
R-W is offline   Reply With Quote
Old 05-03-2013, 07:33 AM   #171
Keithert
Oddometer: 872
Dang, that's a short swingarm. You are going to feel every bump!
2007 Yamaha Royal Star Tour Deluxe
2005 Suzuki V-Strom 650
2005 Yamaha XT225
1998 Ural Deco
Keithert is online now   Reply With Quote
Old 05-04-2013, 07:32 AM   #172
MUS
ActaNonVerba
MUS's Avatar
Oddometer: 25
Honda Corporate Sponsorship
Have you thought about asking Honda to sponser this ride. Pocket change in big corporate budget. I would use the Environmental Responsibility angle to sell them. Imagine all the big adventure bikes that do that 4000 plus miles of the TAT burning gas at the rate of 35 MPG? You guys will do it on 1/3 that. Maybe they can replace your gas guzzling van with a Prius
Here is your link: http://csr.honda.com/environment/nor...mental-report/
MUS is offline   Reply With Quote
Old 05-04-2013, 09:39 AM   #173
LashLarue
LashLarue's Avatar
Oddometer: 163
Seat covers
I use the Walmart ATV seat cover on my CT. It is large and I use the extra to go up the front of the basket I have zipped onto my luggage rack. It was under $20 and I don't know if they still carry it. Here is a link from the ct90 website that shows a picture of it:
http://hondatrailcts.yuku.com/topic/3758#.UYUpM8rgVq0
I too use an XR250 tank for extended range. Most of the guys relocate the key to use the tank but I use it infrequently so I just unplug the ignition key and connect (hotwire) the ignition on when using it.
I still have the original engine but ran a Chinese carb for two years. Only problem that I had was one time when riding the idle jet unscrewed and fell into the bowl.
Good luck and I wish I was there riding along.
The van - classic. You might want to change all rubber (belts and hoses) before the trip even if they look good. Cheap insurance against two of the top 4 reasons to breakdown (gas and flats).
Another interesting link you might like is from the Aussie Postie Ride where they ride across Australia on ct110s:
http://www.postiebikechallenge.org/faqs.htm
LashLarue is offline   Reply With Quote
Old 05-04-2013, 12:41 PM   #174
Cycles East OP
Oddometer: 128
Once again, nothing has been a direct bolt on for this engine swap. The carb either hits the back bone or the right skidplate support. Cut away the skidplate and will reweld a new one in.
Old 05-04-2013, 12:42 PM   #175
Cycles East OP
Oddometer: 128
CT90 fender mounted a bit lower than stock on the XL125 front forks. This will allow more suspension travel than with the fender mounted at stock height.
Old 05-04-2013, 12:44 PM   #176
Cycles East OP
Oddometer: 128
LED tail light and license plate mount.
Old 05-04-2013, 12:45 PM   #177
Cycles East OP
Oddometer: 128
Front storage rack. Doubles as a guard for the 30 LED head light.
Old 05-04-2013, 12:47 PM   #178
Cycles East OP
Oddometer: 128
Swapped out the old hub for a newer style. Two reasons, this style allows for the brake cable to enter from the top of the hub compared to the earlier models that had to loop around to the rear of it causing a large loop in the cable. Second reason is so we all have the same hub set up so all parts are the same and interchangeable.
Old 05-04-2013, 12:49 PM   #179
Cycles East OP
Oddometer: 128
Kick stand made and mounted. The foot of the stand splits the 4 foot wheel base when its on the ground.
Old 05-04-2013, 12:52 PM   #180
Cycles East OP
Oddometer: 128
Auxiliary fuel can mount made. Going to use the 1.5 gallon oil tubs. I have plent of them sitting around the house so no need to spend extra money on a fuel can..
Times are GMT -7.   It's 01:42 PM.
