Old 06-10-2014, 09:16 AM   #316
rustynut2
Oddometer: 492
Have a question. Looking at the Montana bundle. If I wired the rugged cradle into the bike does the cradle have to stay on the bike permanently or does the wire have a disconnect? Looks like the ram mount is useless if the wire doesn't disconnect.
Work harder, millions on welfare depend on you.
12 T800XC, 14 DRZ 400s
rustynut2 is offline   Reply With Quote
Old 06-10-2014, 09:19 AM   #317
GPSCity OP
GPSCity's Avatar
Oddometer: 99
The cable can be disconnected from the cradle using a small T6 torx driver.
The GPS Super Store. Since 1994. GPS City USA // GPS City Canada
GPSCity is offline   Reply With Quote
Old 06-10-2014, 09:22 AM   #318
rustynut2
Oddometer: 492
That's not very convenient of Garmin, thanks for the reply.
Old 06-10-2014, 09:37 AM   #319
thetable
thetable's Avatar
Oddometer: 1,458
It's really easy to wire in an SAE connector, that's what I did. Just like plugging and unplugging a battery tender. It's not the ideal connector, but it is rugged, fairly water resistant, available, and cheap. I actually chopped several feet out of the harness that comes with the rugged mount, eliminated the headphone jack, but left those wires protected, and just wired for power.
thetable is online now   Reply With Quote
Old 06-10-2014, 09:47 AM   #320
rustynut2
Oddometer: 492
Is there a voltage reducer in the wiring harness or does it take 12 volts. I see in the pic it has something in line, might just be a filter
Old 06-10-2014, 09:52 AM   #321
thetable
thetable's Avatar
Oddometer: 1,458
The only thing in there is a headphone jack. Otherwise it's 12V to the pins.
Edit: And a fuse holder.
Old 06-10-2014, 09:59 AM   #322
GPSCity OP
GPSCity's Avatar
Oddometer: 99
It should be 5v to the pins, with a fuse in-line.
Old 06-11-2014, 07:57 AM   #323
Bootworks
Bootworks's Avatar
Oddometer: 15
Cancelled the Amazon order and placed an order with GPSCity, our preferred vendor. Thank you for your response J. Hope G heals soon!
BW
Bootworks is offline   Reply With Quote
Old 06-11-2014, 08:21 AM   #324
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,230
Sent a PM regarding the Zumo 590. I'd like to pick one up sometime this summer to replace my 550.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Old 06-11-2014, 08:25 AM   #325
GPSCity OP
GPSCity's Avatar
Oddometer: 99
Thanks for the order!
I don't have any incoming PM's from you, can you try again?
Old 06-11-2014, 08:54 AM   #326
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,230
Second attempt, hopefully that went out.
Thanks.
Ed
Old 06-11-2014, 10:21 AM   #327
zodillyicous
zodillyicous's Avatar
Oddometer: 30
Thanks GPSCity for quick response and nice discount on the 590. Greatly appreciated.
zodillyicous is offline   Reply With Quote
Old 06-14-2014, 07:40 AM   #328
Bootworks
Bootworks's Avatar
Oddometer: 15
Placed an order 6/11, delivered 6/13. How's that for quick response and good service? Thanks!
BW
Old 06-16-2014, 09:19 AM   #329
GPSCity OP
GPSCity's Avatar
Oddometer: 99
Thanks guys!
Old 06-21-2014, 12:07 PM   #330
gsstampeder
gsstampeder's Avatar
Oddometer: 1,078
Montana
PM sent for the Montana 600
5 weeks in Baja
gsstampeder is offline   Reply With Quote
Times are GMT -7.   It's 04:18 AM.
