Old 04-24-2013, 07:55 PM   #1
Capt.saveaho OP
Capt.saveaho's Avatar
Oddometer: 312
Scottoiler...
Who's got it and what do you think? For those who know of it I'm doing the Utah 1088 with my dad and chain oil is going to be needed.
Erik
2007 525exc
2011 990 Adventure with 08 S suspension!!!
13hp road race 50
Capt.saveaho is offline   Reply With Quote
Old 04-25-2013, 06:25 AM   #2
LC8rider
LC8rider's Avatar
Oddometer: 658
I have the touring kit fitted behind the plate. I'm on my first change of chain & sprockets from new and I reckon I've another 5000m left in them yet. Bike has done 40,000m. And no, I don't ride like a pu$$y
KTM 950ADV & Suzuki DRZ 400E
LC8rider is offline   Reply With Quote
Old 04-25-2013, 06:46 AM   #3
uk_mouse
Aquatic adventurer
uk_mouse's Avatar
Oddometer: 1,478
I fitted one under the seat. Keeps it nice and clean but it gets a bit hot in there and the oil tends to come out too quickly. I use EP90 gear oil in it which is a bit thicker (and cheaper!) but really I should get round to mounting the Scottoiler in a better location.
Soon someone will be along to tell us you don't need to oil an O ring chain
"When compared to other motorists attempting to escape a zombie outbreak, dirt bike riders have a 23-to-1 survival rate." - The Zombie Survival Guide by Max Brooks
uk_mouse is offline   Reply With Quote
Old 04-25-2013, 07:12 AM   #4
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 507
correct, you don't...
BUT:
chainlife is extended if you keep it clean, and that is exactly what the scottoiler does (maybe a little less with thick oil): it washes the dirt of and makes sure corrosion stays away longer AND: keeps the o-rings from drying out & destroying themselves...
And that prolongues chain life ;)
I've mounted mine like this: (not a scottoiler, nor my picture, but same location)
KTM 990 Adventure (Stealth one ; 2008-), now S-d & Beta 350 RR 2013 to play with
Suzuki DL-1000 V-Strom (2004-2008) and Suzuki GSF 600 Bandit (2002-2006)
www.roeligan.net
Roeligan is offline   Reply With Quote
Old 04-25-2013, 08:41 AM   #5
Unruled
950S
Unruled's Avatar
Oddometer: 120
I have the Tutoro auto-oiler, even less hassle, cheaper and it works a treat. After you've found a sweet setting, that is, I drained an entire reservoir in the first 30 miles using factory recommendations. I guess they don't factor in off-road use, it being kinetically activated and such...
If you can't fix it with a hammer, you've got an electrical problem.
Unruled is offline   Reply With Quote
Old 04-25-2013, 08:56 AM   #6
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,012
I settled with these
http://ptlube.co.uk/motorcycle-chain-oiler/
After two sets of scotoiler, I found them distorting in high temperatures. Scotoiler need to run "cool". Away from exausts and motor. The tools compartment isn't cool enough. Cheers.
Old 04-25-2013, 10:05 AM   #7
stevodadevo
What happened?
stevodadevo's Avatar
Oddometer: 177
Oiling your chain?! pfffff
stevodadevo is offline   Reply With Quote
Old 04-25-2013, 11:34 AM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,012
Yeah, I know, it is a gay thing to do...
Originally Posted by stevodadevo View Post
oiling your chain?! Pfffff
Old 04-25-2013, 05:12 PM   #9
Capt.saveaho OP
Oddometer: 312
I'm going to take a look at them, I'm going to average about 1100 miles a day do it won't get much rest.
2007 525exc
13hp road race 50
Old 04-25-2013, 05:54 PM   #10
Kikemon
Poseur
Kikemon's Avatar
Oddometer: 274
I had the Scott electronic (pump) oiler - "e system" or some such after going through two of the gravity fed types. I never could get any of them to work too well. The gravity fed ones seemed to either dump too much oil or none at all and the e-system kept resetting itself and basically turning itself off. I would think that for a long road trip a gravity fed one would work once you got it dialed in. It seems like the settings you would need on a long day of touring are very different than what you would need for commuting or around town riding. I don't have one now because I am fed up with trying to get them to work, but I still like the concept. It is just that the execution is lacking. They can put a man on the moon...
Kikemon is offline   Reply With Quote
Old 04-25-2013, 08:12 PM   #11
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
You've said from experience what I've always thought about the Scottoiler. I am in the camp that believes an O or X ring chain doesn't need lube. However, I do spray this on from time to time:
Old 04-25-2013, 10:10 PM   #12
Just Paul
Pro Cat Herder
Just Paul's Avatar
Oddometer: 2,102
I run the oiler I like it but its messy
Extends my chains life by double
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
“The world is a book and those who do not travel read only one page.” – St. Augustine
Just Paul is offline   Reply With Quote
Old 04-26-2013, 04:09 AM   #13
JanB
JanB's Avatar
Oddometer: 232
I kept the oil-lines short and the oiler within easy access... its a little messy, though... but thats the point of it. Washing away the dirt.
http://demjansein.wordpress.com
JanB is offline   Reply With Quote
Old 04-26-2013, 04:47 AM   #14
Gimme 2
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,138
Why not have a push button on the handle bar, pisst your good for 200 ks.
I have been using wd 40 for about 6 years , it helps degrease the chain before you wash then spray the chain off with a hose , then straight away drown it in wd 40 . i'll use Chain lube for long distance dusty stints over 300 k and pre extreme mud racing, it creates a thick sticky barrrier which seems to help keep sand out better. its good stuff but not nessesary Its messy and expensive. A clean and well lubed chain is a beautiful thing.
Gimme 2 is offline   Reply With Quote
Old 04-26-2013, 06:45 AM   #15
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Not to take this thread to that place but these two suggestions are a huge no-no with sealed o or x ring chains.
Firstly, WD40 is a penetrant and degreaser, with minimal lubricating properties. It penetrates PAST the rubber sealing rings and clears out the grease that the chain manufacturer put in there. Once the WD40 clears out that grease in behind the sealing rings it is impossible to replace it. It pretty much turns your o or x ring chain into an unlubricated chain. So, WD40, not recommended. I know, I know, 'you've been using it for years and haven't seen any problems with it'. That is an honest response. However, the damage WD40 does is not visible to the naked eye. It exists behind the rubber o or x type sealing rings.
Secondly, spraying the chain with water is never necessary or recommended when cleaning an o or x ring chain. The main reason is that the water, if pressurized, can blow past the rubber sealing rings and get in where the grease is sealed in by the manufacturer. This will cause rust, corrosion, and break down of the grease that the chain manufacturer put in there. Secondly, water will make the chain rust in no time. Water to clean chain? No.
Sorry, dude, but I couldn't let this one go unnoticed.
Times are GMT -7.   It's 10:42 PM.
