Old 09-06-2013, 05:18 PM   #1
Hikertrash OP
Oddometer: 2,906
ADVdesigns Lower Crashbar Help
Does anyone still have their instructions for the 1200GSA Advdesigns lower crash bars? I need to reinstall mine after the OEM GSA crash bars were damaged in a crash and I need to know what size the two bolts are that mount to the GSA crash bar.
Hikertrash is offline   Reply With Quote
Old 09-06-2013, 06:22 PM   #2
88gspd
Daydreamer
88gspd's Avatar
Oddometer: 17
Here you go:
3. Place engine guard on motorcycle with rear hole over the aluminum plug. Insert Allen head M8 bolt with fender washer and lock washer using a 6-mm Allen wrench. Leave very loose and apply liquid tread lock.
4. Insert M6 clamp bolt with liquid thread locker through forward hole in the bar clamp with the guard in the middle of the clamp using 5-mm Allen. Leave very loose. Insert the M4 bolt through the bar clamp and engine guard with liquid thread locker using 4mm Allen. Leave loose. Caution: (When instructed both bolts must be tightened evenly in half turn increments to prevent binding.)
5. Install M10 bolt with a small washer on the outside and large washer on the inside with the nylon-locking nut using and 8-mm Allen wrench and a 17mm open-ended wrench. Leave loose.
Torque Specs:
M6 - 17 Nm, use liquid thread locker
M4 - 1/4-20 bolt - 7 Nm, use liquid thread locker
M8 - 27 Nm, use liquid thread locker
M10 - 40 Nm, DO NOT use thread locker on these bolts because they already have a nylon lock.
2011 BMW F800GS
2007 BMW R1200GSA (gone)
2007 KTM 640A (gone)
1988 BMW R100GSPD (gone)
88gspd is offline   Reply With Quote
Old 09-06-2013, 06:35 PM   #3
Hikertrash OP
Oddometer: 2,906
Thank you
Times are GMT -7.   It's 12:31 AM.
