Old 04-26-2013, 03:44 PM   #1
R-dubb OP
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,795
Gotta question about wheels
I'm trying to marry a snowflake wheel and a new style fork with 25mm axle.
Is it possible? I can have an axle and/or spacers machined. But fitting a 25mm axle through an 17mm hole is a different kind of trick.
R-dubb screwed with this post 04-26-2013 at 04:37 PM Reason: correct size
R-dubb is offline   Reply With Quote
Old 04-26-2013, 03:59 PM   #2
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,469
Is it possible? I can have an axle and/or spacers machined. But fitting a 25mm axle through an 18mm hole is a different kind of trick.
What's the OD of the wheel bearing? See if you can find a different wheel bearing with the same OD and 25mm ID.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 04-26-2013, 04:38 PM   #3
R-dubb OP
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,795
There's no such thing as a new question on this site
http://www.advrider.com/forums/showthread.php?t=827359
Old 04-26-2013, 05:03 PM   #4
R-dubb OP
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,795
Looks like I'm barking up a tree.
Closest size in a sealed ball bearing is 25x42x9.
Roller bearing (non-tapered) is 25x42x17.
Also mentioned is difficulty matching up rotors, but I do have some K bike rotors milling about. Bigger is better, if I can get the alignment worked out. Maybe more work than it's worth.
Old 04-26-2013, 07:55 PM   #5
bmwrench
Oddometer: 2,062
Make up a sleeve.
bmwrench is offline   Reply With Quote
Old 04-27-2013, 11:22 AM   #6
Prutser
Prutser's Avatar
Oddometer: 969
Something like this :
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 04-27-2013, 12:03 PM   #7
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,773
Edray, here on the site did this on his R100S. He used late model inverted GSXR forks, and brakes on his snowflake wheels. This required using the original dia. axle, then machined spacers that fit the forks. Then spacer discs for the rotors, to make for proper spacing. He also re drilled the rotor hole spacing.
This last step can be avoided, by using Ducati, or Yamaha FZR rotors (not sure what years, etc).
Old 04-27-2013, 08:48 PM   #8
Houseoffubar
fine beer sampler
Oddometer: 1,773
Sorry I was in a rush this morning! Here's a link to Edray's build.
Modern retro build
Old 04-28-2013, 04:55 PM   #9
R-dubb OP
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,795
Modern retro build
What a great thread! You do some fine work.
Yes, the snowflakes look great in black. Those caliper brackets look good too. I'm still moving in about four directions at the same time. Thanks for the tips.
Old 04-29-2013, 03:45 PM   #10
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 633
Originally Posted by r-dubb View Post
yes, the snowflakes look great in black
+1
Ras Thurlo is offline   Reply With Quote
Old 04-29-2013, 07:34 PM   #11
mendoje
Oddometer: 235
Originally Posted by Ras Thurlo View Post
+1
+2
They look so good, when I first opened that thread, I thought they were spoked wheels. Very nice!
2004 BMW R1100S / 2003 Ducati M800Sie / 1986 R80 G/S / 1993 Suzuki RMX250 / 1981 BMW R100RS (Sold ) / 1977 Kawasaki KE100 (1st Bike )
mendoje is offline   Reply With Quote
Old 04-30-2013, 09:15 AM   #12
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,462
Yes this is possible. I did this to Andy Goldfine of Aerostich's R80G/S just before he and Helge Petersen did their China and Russia trip many years ago.
The parts I started with were a R100GS front end and the R80G/S wheel. These both have the same axle and wheel bearings as your application. You need to machine a spacer for the fork legs and for the axle and if I remember correctly it was easier to use a rear axle from any drum brake post 1970 model as they are a little bit longer than the 1975-84 17mm front axles.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-30-2013, 07:49 PM   #13
mendoje
Oddometer: 235
Perfect timing, I'm thinking about doing this! Is the spacer in the fork split, so that the fork can clamp on the axle?
Jeff
Old 04-30-2013, 08:18 PM   #14
Boxer Metal
Mad Scientist
Oddometer: 3,462
Jeff
It couldn't hurt.You could also add a step to it so it stays in place.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 04-30-2013, 08:25 PM   #15
mendoje
Oddometer: 235
Perfect! Dont want to hijack this thread, so PM sent on one last question regarding R80G/S wheel + R100GS forks.
Thanks! Jeff
Times are GMT -7.   It's 11:01 PM.
