Old 04-26-2013, 05:40 PM   #1
ciukes OP
ciukes
Oddometer: 25
LC4 Water Pump - Plastic impeller shattered
Hi guys,
Reviewing recently purchased 640 '01 I discovered this
The bike has 5000 miles on the counter but lots of owners. I suspect it was ridden in off-road a lot. I replaced the impeller and checked all the hoses and drained water and I found all the impeller bits.
Question: Should I be worried about plastic impeller being shattered? Can this signal a major problem I'm not aware of or this "just happens" ?
ciukes is offline   Reply With Quote
Old 04-26-2013, 08:12 PM   #2
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,247
Originally Posted by ciukes View Post
Hi guys,
Did you rebuild the water pump? With the bike being 12 yrs old it would be worthwhile to replace those old rubber seals in the pump...
gunnerbuck is offline   Reply With Quote
Old 04-27-2013, 08:43 AM   #3
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 839
Bolt and washer look suprisingly fresh for that old bike?
But its not very common to impeller shatter like that.
Maybe there was something gone/made wrong on previous maintenance...
Seikkailu_R is offline   Reply With Quote
Old 04-28-2013, 12:17 AM   #4
ciukes OP
ciukes
Oddometer: 25
Certainly it is a goog idea:) That's what I'm doing right now.
To Asia and beyond. Low-budget travels on two wheels
mototraveler.eu
Old 04-28-2013, 12:19 AM   #5
ciukes OP
ciukes
Oddometer: 25
Makes me think somebody replaced it over time.
That's the only explanation I could come up with.
Anyway impeller is replaced now and all the cooling circuit is going through review in search for old impeller's bits :/
mototraveler.eu
Old 04-28-2013, 04:06 PM   #6
rz35027
rz35027's Avatar
Oddometer: 237
Bluhduh
Try to match all the larger bits to the broken impeller to make sure you get it all...
I had an overheating problem when I first got my bike, after having to tear the engine down I found bits of impeller blade jammed in the coolant tract behind/infront of the carb. Apparently the P/O had just installed a new impeller and sold the bike
My best guess was mechanical error or he had kicked the bike over when it was frozen(?)
rz35027 is offline   Reply With Quote
Old 04-29-2013, 09:33 AM   #7
Droptarotter
Oddometer: 1,273
That's the most probable answer there!
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Times are GMT -7.   It's 02:47 AM.
