Old 03-27-2013, 02:28 PM   #1
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
Mother of all oil-threads
Ladies and Gentlemen,
In the old days, we would run 10w-40 SF in winter and 20-50 SF in summer.
Done deal.
With the camhead, and now the wethead, things aren't that simple any longer.
I have had a proud owner of a wethead quote from his Owners Manual. No longer does it say "Oil requirements", but the term is "suggested".
If you have any fantasy at all, you can imagine how many oil-threads will arise from this.
Thus, we, here in the Mother of all Oil Threads, need to figure out what the Official GSpot FAQ Recommandation should be.
Now, I am not very interested in what you personally think is the best oil. Or if Redline worked well in you '74 Commando, but rather what BMW requires for the '10 camhead and the new wethead.
I know that the Owners Manual for the wethead says "Suggested oil: 5w-40 SL", but what does that mean? What does the engine require?
Now, if you have access to a wethead manual you will notice that a particular producer is "suggested". If you know anything at all about oil, you will carefully refrain from dragging the producer into this. We want to advice our fellow travelers on the requirements, not some local producer.
So, please enlighten me, and I will keep the GSpot FAQ abreast on the news.
Thank you!
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 03-27-2013, 04:11 PM   #2
Tmaximusv
Tmaximusv's Avatar
Oddometer: 859
This will all end in tears.
Illegitemi non-corundum est.
Tmaximusv is online now   Reply With Quote
Old 03-27-2013, 04:13 PM   #3
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
A drop of oil can't hurt.
[TaSK]
IBA: 33616
Old 03-27-2013, 04:43 PM   #4
nwpa
Generally amused
Oddometer: 499
Yeah this can't end well.
I'll see you again on page 32.
nwpa is offline   Reply With Quote
Old 03-27-2013, 04:51 PM   #5
DGraham
Oddometer: 255
Seems to me that even BMW is saying it really doesn't matter. Case closed.
My bet is this will be the last post
DGraham is offline   Reply With Quote
Old 03-27-2013, 04:54 PM   #6
orgo
Oddometer: 262
Same oil you've been using. 10W-40 SF ACEA A2
orgo is offline   Reply With Quote
Old 03-27-2013, 05:52 PM   #7
Andylaser
Heavy Metal
Andylaser's Avatar
Oddometer: 1,090
[TaSK]
No it didnt.
It suggested "Castrol Power 1 Racing SAE 5W-40, API SL / JASO MA2"
I take this to mean they would like you to use "Castrol" brand oil, but other brands with similar properties will be acceptable.
but what does that mean? [TaSK]
It means the engine requires SAE 5W-40.
It really isnt rocket science.
Sent from my binary data processing apparatus using magic and wires
OLD SKOOL HEAVY METAL
Andylaser is offline   Reply With Quote
Old 03-27-2013, 06:18 PM   #8
BTL
No more snow!!
BTL's Avatar
Oddometer: 421
For those that have access to this Mag....this months BMW MOA has super technical article on oil, with more graphs and technical info than any oil thread needs.
I left the magazine in the bathroom......think I'll just read the owners manual from now on.
BTL is offline   Reply With Quote
Old 03-27-2013, 08:27 PM   #9
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,414
If I had one of those wetheads, I would use 5-40 HDEO...cheap and available and used in diesel engines 'round the world. As for brands, Shell Rotella, Mobil Delvac or Chevron DELO here in the colonies.
def is offline   Reply With Quote
Old 03-27-2013, 08:45 PM   #10
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 1,005
Task, Sir.
That was a remarkable re-branding of the oft cursed thread. I'm uncertain
if you are sincere or have a slightly twisted vision of humour.
Please advise.
Yes I am quite serious.
Mike Ryder is online now   Reply With Quote
Old 03-28-2013, 01:00 AM   #11
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
So your interpretation of "Suggested" is that only the first part is a suggestion and the second a requirement.
The question that will come is this one: When needing oil at some remote place, can I use 10w-40 on the wetheat.
Your interpretation is that the answer is no.
Did I get that correct?
[TaSK]
IBA: 33616
tagesk screwed with this post 03-28-2013 at 01:18 AM
Old 03-28-2013, 01:07 AM   #12
configurationspace
delooper
configurationspace's Avatar
Oddometer: 8,970
Fresh oil tends to work better than broken, used or contaminated oil. But even some used oil can be okay. This is what my research is telling me.
configurationspace is offline   Reply With Quote
Old 03-28-2013, 01:17 AM   #13
tagesk OP
Tuscan rider
tagesk's Avatar
Oddometer: 3,228
Originally Posted by Mike Ryder View Post
Task, Sir.
Please advise.
Shakespeare to the rescue:
Originally Posted by Hamlet
Beware
Of entrance to a quarrel, but being in
Bear't that the opposed may beware of thee.
It is not clear from the manual (on the wethead) if BMW mere suggests a producer or if they also suggest a viscosity and quality.
Nice if I mis-read (not native Over There, you know) and, as mentioned above, 5w-40 is the requirement.
For the GSpot FAQ, a single requirement is nice. But the question of 10w-40 will arise shortly, and I am trying to have it settled before we need the answer.
Please notice that 10w-40 has already been suggested by one poster above!
I'll write 5w-40 API SL in the FAQ for now. Please keep your eyes open for alternative sources of information. The "Repair CD", for example.
[TaSK]
IBA: 33616
Old 03-28-2013, 06:05 AM   #14
Disco Dean
Disco Dean's Avatar
Oddometer: 1,283
5w - 40w motorcycle oil - simple
10w - 30w motorcycle oil
20w - 50w motorcycle oil if it is hot out sure
Wethead is a wet clutch bike so it would not be advisable to use a basic "car/truck" dry clutch based oil as it has added friction modifiers that will encourage a wet clutch to slip.
With the wethead - gone are the days of cheap car or diesel oil.
Anything in the range of 5w to 40w is fine with the same specs - depending on climate and usage. The larger the gap between the numbers the harder the oil has to work....
Any number of major brands will work well and fit the manuals suggestion.
youmoveyou
As your attorney, I advise you to buy a motorcycle. How else can we cover a thing like this righteously?
Disco Dean is offline   Reply With Quote
Old 03-28-2013, 06:29 AM   #15
bracky72
Oddometer: 965
A little birdie told me mobil1 0w-40 is the holy grail....
bracky72 is online now   Reply With Quote
Times are GMT -7.   It's 06:45 AM.
